build this board to getting started with the SAMD microcontroller family after I made the mistake to try the much bigger SAMD21 first. The SAMD09 used here is he smallest from this family and therefore has the shortest (still 709 p.) datasheet. I think this board will be, as my other microcontroller breakout boards, very useful for an early prototyping phase on breadboard. So far I quite like the SAMD09. If you compare it to the the ATmegas there are a lot more possibilities. Maybe this is the Arduino Nano killer for me.
Features
- 3.3V 0.8A LDO (1117-3.3)
- powered from USB, Vin pin (3.6-13.8V) or regulated 3.3V
- on board USB to serial bride IC (CH340)
- reset switch
- SWD programming header
- optional 32kHz crystal (if not needed pins can be used as additional IOs)
- on board user LED (connected to PA02)
- on board power LED (connected to 3.3 rail)
Schematic
Partlist:
Part Value Package Comment A08 0603 User LED connected to PA08 C1 100n C0603 C2 15p C0603 optional C3 15p C0603 optional C4 10n C0603 C5 100n C0603 C7 100n C0603 D1 MBR0520LT SOD123 power selection diode D2 MBR0520LT SOD123 power selection diode IC1 CH340G SOIC16 USB-UART bridge IC2 1117-3.3 SOT223 LDO JP1 1X08_OCTA pin header JP2 1X08_OCTA pin header JP5 2X05_1,27B programming pin header K1 mini USB generic Mini USB connector PWR 0603 Power LED Q1 3215 3215 optional external 32kHz crystal Q2 CSTCRCSTCE CSTCESMALL 12 MHz resonator for CH340G R1 solder / 0 R0201 PA08 - pin header R2 solder / 0 R0201 PA09 - pin header R3 120 / 220 R0603 resistor for power LED R4 120 / 220 R0603 resistor for user LED R5 ~10k R0603 pullup for reset S2 SMDSWITCH Chinese SMD switch U$1 SAMD09SOIC14 SO14 ARM Cortex M0+ microcontroller
PCB
The PCB design is quite compact and does fit on an normal breadboard:
On the Top side (left image) are all components which must be accessible like USB connector, programming header reset switch and LEDs. To archive this compact format with some tricks were used like vias on pads (this is no good design practice) and the two connections of the LDO for Vout are use as trace. So this will not work without the LDO if powered externally with 3.3V
Thinking on / ideas for the future / notes
- A Hint when working with the Event System (EVSYS):
- In the Channel Register (CHANNEL) the bits [2:0] are the channel nuber like normal (0b000->channel0 0b001->channel1)
- BUT in the User Multiplexer Register (USER) the bits [11:8], which are also for the channel selection are channel#+1.( A zero means no Output in this case). So 0b0001->channel0, 0b0010->cannel1 and so on.
- This took some time for me to notice that, although is it also written in the datasheet (p.409 Table 23-5).
- This board should also work with the SAMD10C14 which has more features (like a DAC) and twice the amount of flash (8k->16k)
Errata
Rev 1.0 (date on the boards 3'16)
- The led label is wrong. It should be A02 instead of A08
Rev 1.1
Similar projects
This project is inspired and/or based on some of them:
Alex
Just4Fun
ajlitt
Dave Vandenbout
thank you for the mention! I just finished the serial bootloader for samd09 boards. Still need to do some code Cleanup and create a Readme, but if you want to check it out its on my github linked in the project.
Have a great fourth.
