Spare boards force a twin tesla coil
A project log for RPI (zero) Tesla Coil Controller
A small tesla coil controller designed to be run from a Raspberry PI
extreme-electronicsExtreme Electronics • 06/08/2016 at 18:24•0 Comments
OK, so its OSHPark's Fault. You get three boards.
I got my prototype up and running had had a couple spare. As Its I2C from the PI to the controller, It was easy to set a different address and run two controllers on the buss.
Here is the result running at the Notts Gaussfest 2016 running at low power due to no heat-sinks.
I now have the heat sinks, just need a box (as most of it is live and open to fingers :(
