Proper case from old acrylic sign
A project log for RPI (zero) Tesla Coil Controller
A small tesla coil controller designed to be run from a Raspberry PI
extreme-electronicsExtreme Electronics • 12/03/2016 at 22:35•0 Comments
Realising that if I was going to be moving this project around a single acrylic base with all of the "live" components on was not such a good idea I have created an acrylic box from 6mm acrylic from a recovered sign.
You can see this case in use in the following Demonstrations of the PIZero Teslacoil
