I wanted an easier way to connect power and seen other boards available for server supplies that looked great but none that i found for the DPS-1520AB. series supply
so I set out and made my own based on various pinout information found online
The Supply Side receptacle: (ON THE DPS-1520AB)
Internal Header (Amphenol FCI Part: 51939-104LF)
Breakout Board Side hotswap:
PCB Header (Amphenol FCI Part: 51915-101LF)
pci-e connectors: (18awg 7.5A 30 Deg C max temp rise 32.2 max per pin)
Molex 6 Pin pci-e connector (Molex part: 0039281063)
Connectors to connect to pcb via wires
6 Pin PCI-E Male Connector (Molex part: 0039012060)
Crimp pins for 14-18awg wire:
Crimp Pins (Molex part: 0039000038)
the two solder jumpers are for power and fan speed
Also I would recommend using 2oz copper if you make one
Charles Lakins
bobgreenwade
technolomaniac
TheBrokenEngineer
Stefan Lochbrunner
Is there any way to adjust output voltage on theese ? I have two and I need to get 13,7 Volts out of them to supply cars while programming.
