Updated Changes & Library File
07/01/2016 at 19:48 • 0 commentsUpdated changes to accommodate pins for both spacing and hole sizes
Library Footprint Changes
06/30/2016 at 14:20 • 0 commentswell the first rev3 arrived from oshpark , however the pci-e footprint needs adjustment
and the hotswap connector holes need to be more oblong for the blade pins as there more shaped like sewing needle heads or spears
Awaiting the new correct connector to compare its design to before changing that again
Breakout connector found
06/23/2016 at 19:31 • 0 commentsBreakout side Connector was finally found its part numer is: 51915-101LF
However the MOQ is 200 units from one of Amphenols Re-seller distributors
Data sheet attached
Amphenol Parts
06/21/2016 at 22:12 • 0 commentsHave been sourcing the correct part for the supply connector and Amphenol North America are getting back to me soon with the actual part number from the Asia Pacific branch that was the one who supplied them to Delta Electronics
the supply side connector here: (Pwrblade FCI 51939-104LF) http://www.digikey.com/product-detail/en/amphenol-fci/51939-104LF/51939-104LF-ND/5200275
data sheet attached to files
DigIkey pointed me to the wrong hotswap connector
06/15/2016 at 23:55 • 0 commentsthe board files wrong for the supply for the connector, as well as the part listed
when i showed the pictures of the supply digikey pointed me to the one i used in my design, today the supplies arrived and it doesnt fit by a mile its too long and spacing is off
online it looks the same and i idnt have a supply here to verify the measurements that wasnt in use
Board size reduction
06/14/2016 at 19:33 • 0 commentsAnother Library update to reduce outline of connector (rev3a)
Also made board smaller for reduced production cost
Library Footprint Fixed
06/08/2016 at 19:51 • 0 commentsThe oshpark link is ok now to produce, the mounting tab holes were too far from the pcb edge to align with the pins too,
If you produced a board by chance you can snip off the pcb insert tabs and it should still work ok, Ive updated the oshpark link and libray file
Under Dev - Dont produce any osh boards yet
06/08/2016 at 01:40 • 0 commentsIm awaiting the oshpark boards in hopes the footprint is right, so hold off ordering boards until I can verify fit of the main connector
Fingers crossed its right due to the fact its $31 and change for three boards to find out it was a wasted run
Charles Lakins
