AxVision: Vision experiments
10/16/2016 at 11:39 • 0 commentsWhile I'm waiting for the aluminum parts, I've started the vision tests using a webcam. The application is written in C#, using the Emgu.CV libraries. I'm experimenting with edge detection for the alignment of the components. To be continued...
The material arrived today!
10/12/2016 at 14:28 • 0 commentsToday I received aluminum profiles, and the two bars 16x600 mm for mounting the frame and the y axis. The remaining aluminum plates are in the process and hope to receive in a few days.
The process is very slow, but I have little time to devote to the project.![]()
Design changes
08/03/2016 at 15:14 • 0 commentsI have made small changes to optimize the work area, and avoid collisions. Soon receive aluminum parts for the Y axis.
For the moment, I placed a image of new Y-Assembly in the galery.
Y-axis changes
06/20/2016 at 11:05 • 0 commentsI modified length of Y-Axis from 500mm to 600mm, and the machine frame for reflect this change.
Axis
06/09/2016 at 15:27 • 0 commentsFor logistical reasons, I start the development by the X axis
This is de definitive design for the moment.
Here the implementation, not exact, but sufficient for the first software and hardware tests.
Rafael Serrano
