Eppur si muove!
01/21/2021 at 20:17 • 0 comments -
Updates on GitHub
10/27/2019 at 11:28 • 0 commentsToday I've added links to github for the operating system, pcb tools and some other utilities for the project.
Limit sensors
08/11/2019 at 19:36 • 0 commentsLately this week I've installed the X and Y axis limit sensors. Each sensor is mounted into the supports of the linear guides. Said sensors have each two LED's indicators and work at 5 volts — this can be changed to any voltage, though.
Thera are a RAR archive with schematics and board files in Eagle format.
Basic structure finished
08/04/2018 at 10:21 • 0 commentsAfter almost two years, the basic structure of the project is finally finished ― axes X and Y.
It is necessary to fix some details of the CAD files. Also, the list of materials has to be written as well. From now on, I will continue to develop the electronic controls of the motors and limit detectors.As for the Z axis, it is not yet decided how to implement it and is still under study.
The Axis V1.0:
Y motor detail view from rear:
Y slider:
Base structure:
Y motors:
Y free pulley detail:
X motor:![]()
X axis from bottom:![]()
Y slider detail:![]()
View of X axis from motor side:![]()
That's all for now. Follow the project for more updates.
The last axis changes details
04/01/2018 at 15:59 • 0 commentsY axis motor:
Y axis pulley:
X axis motor:
X axis pulley:
Latest design changes.
03/31/2018 at 20:15 • 0 commentsAfter a few months of inactivity, I continue with the Axis project.
Y axis:
- Change in the system of hooking the drive belt, which involves raising the motor, and the free pulley.
- Change in the support plate of the X axis
X axis:
- Remodeling complete, to work with the guides in vertical.
- Use the same philosophy as in the Y axis
Z axis:
- Replanting the system. To study.
In a few days the base structure and the Y axis will be completed.
Y-Axis motor module
07/30/2017 at 12:52 • 0 commentsToday I finished machining and mounting the Y-axis motor module. All measurements and tolerances seem correct. Anodizing is missing, but we'll leave it for later. In a few days I will have the entire structure.
Aluminium parts for Y-Axis
07/02/2017 at 16:42 • 0 commentsI've finally received the aluminum parts for the Y-axis assembly. They had been cut by water-jet. The holes and threads need to be machined.![]()
3 Axis FPGA controller
12/03/2016 at 18:48 • 0 comments![]()
At the moment I have finished the prototype 3-axis motion controller with a DE0-Nano board. The simulation was performed with Verilator, and the synthesis and programming with Quartus-II v13.1.
The model is written in system verilog. It includes several modules, the most important of which SCurveGenerator, LinearMotion and ALU, with a Look-Ahead carry.The system generates the STP and DIR signals for three step motor controllers. As parameters requires JERK, and the definition of S ramp. The process starts when receiving the GO signal.
I forgot to mention that the number of axes can be configured using the NUM_AXIS parameter from 2 to 16
Soon more and better -
AxVision: Vision experiments (2)
10/16/2016 at 12:12 • 0 commentsEt voila!
Edge detection on a clear black & white image, using an "USB microscope cam".
Next:
- Detection of rectangles (Components) and circles (Fiducials).
- Compute centroid.
- Compute angle deviation for rectangles.
- Make real scale grid for calibration.
Brainstorm:
- Test type of ilumination (Red leds or white leds). Actually the microscope use 3 white leds.
- Use hardware system FPGA+CAM (DE0 Nano) or software system (OpenMV) as an independent detection module. Expensive but beautifull.
Rafael Serrano
