1Step 1
How it works
2Step 2
The Lens
The lens was a tricky thing. I had not really an Idea about optics. So I googled and googeld, and I learned a lot about real images, virtual images focal points, and magnification. The best working lens is an Acrylic Plano convex lens with a focal point of 100mm. If you place the screen at a distance of 73mm from the lens away, you will get a virtual image at a distance between 27-30cm. The magnification factor is x3
That's perfect, because another important thing is, that your eyes can only start focusing things at +-25 cm
I found this website to calculate the object distance.
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/image4.html -
3Step 3
The electronic
Here are all the parts for the data glasses
I just used a smaller battery.
To use the 280mA battery, I had to change the 3k resistor against a 5.6k resistor on the original board. The charging current is now reduced to +- 200mA.
4Step 4
The enclosure.
for the first tests I used an enclosure made with cardboard. This was a cheap solution and worked very well
For the final version, I used my 3D printer. The style file has been created in 123design. I need to make a few modifications to the design, but it's not bad for the first try.![]()
5Step 5
Connecting the Owon B35T Multimeter with the data glasses
This multimeter has an intern bluetooth 4.0 communication, so you can connect it to your phone or tablet
I had to reverse engineer the serial protocol.
Config of the BT module.
I used a simple Arduino program to send and receive Data to and from the module.
First you have to set the module to Cental.
AT+ROLE1 moule = central AT+RESET reset AT+SHOW1 show Bluetooth name in response AT+IMME0 connect automatically AT+FILT0 scan for devices AT+DISC? Show devices To connect to the Owon B35T type AT+CONE0(Mac adress of the Multimeter)
These softwares can be found at my github https://github.com/awall9999/Arduino-Glass
6Step 6
The Arduino Data Glasses
Alain Mauer
Parabens pelo projeto Arduino Glass, sou do Brasil.... Sou estudante de analise e desenvolvimento de sistemas, gostaria de usar seu projeto para tentar fazer implementacao, tentar desenvolver um sistema que interage com o arduino glass com celular atraves do
Bluetooh , conseguindo essa proeza disponibilizarei o codigo para voce, colocari um link para que todos veem seu projeto Arduino Glass. Um abraco.
Congratulations on the Arduino Glass project, I'm from Brazil .... I'm a student of analysis and development of systems, I would like to use your project to try to implement, try to develop a system that interacts with arduino glass with cell phone throughBluetooh, achieving this feat will make available the code for you, will place a link so that everyone sees your project Arduino Glass. A hug.
Hay,
I am thinking about installing a ready made eye piece in the display box. That can replicate a monitor or tablet screen. Some what similar to OLED viewfinder in new mirror-less cameras.
Do you think that will work. I know I might have to change the lens, but the mirror and reflector will work or not.
GP
