Feeling pissed off
02/26/2018 at 21:08 • 15 commentsI'm really feeling pissed off, when I see people using my designs and try to sell them as their idea.
This guy makes a nearly 100% copy of my Data Glass and only after I send him an email he added "inspired by Alain^s Projects". just inspired, really ???????
I think that's not the way open source should work. If you use the work of someone else, the minimum is to mention this person and set his website link in the description.
The only thing which calms me down, is that it is still my invention and other people will know it.
Lens Alternative
12/18/2016 at 11:27 • 2 comments -
New Display 0.49 inch
10/18/2016 at 19:56 • 5 comments -
Things to do
10/10/2016 at 07:24 • 0 commentsThinks to do:
- Finishing the Software, to auto connect to a Owon Multimeter
- Adding a battery indicator in the display. The BLE module has this feature.
- Building different reflectors with tint and mirror foils, to make the glasses work in a bright area,
- Reducing the weight and redesigning the enclosure.
- Testing with a smaller 0.49 inch display.
- Creating a technical Data sheet
The end is near
09/19/2016 at 16:07 • 0 comments -
Modifying the charger circuit
09/17/2016 at 19:28 • 0 comments -
A small reflector modification
09/16/2016 at 07:43 • 0 comments -
I looks like this will be the final design
09/15/2016 at 08:33 • 0 commentsI finally start handling the 123Design software and my 3d Printer.
I was totally focused on my cardboard design enclosure, but at the end, I had to redesign the glasses due 3d print problems. Now you can adjust the reflection screen, to get the best view.In the next few days I'll test the electronic with the new LiPo, but I'm still waiting for the lenses. -
B.T. Data Glasses in his new enclosure
09/02/2016 at 16:08 • 2 comments -
First 3d printed enclosure
08/31/2016 at 07:25 • 0 comments
