Lipo 3.7V
07/13/2016 at 16:31 • 0 commentsMy lipo finally arrived.
And charging ...
I found the "easy to find Lens"
07/11/2016 at 17:53 • 0 commentsThe main challenge was to build it with easy to find parts, but the lens is a problem. I had a pair of perfect lenses (the lens on the right. A plan convex lens with a size of 33mm and a FL of 100mm), but these are difficult to find. In China I had the possibility to buy them by 100 pieces min. order.
So I took the weekend for a few optical tests and the winner is.... the lens of my magnifying head glasses. There are 3 lenses in the set, but the one we need is the big one with a magnifying of 3,5.The frame of these head magnifier will be used to hold the data glasses.
And the price of the whole thing is about 10$.
It has a focal length of 12cm so that the way from the screen to the lens will be 8,1 cm, with a magnifying factor of 3,. On picture 2 you can see how I found the focal length.
Lens Calculation
07/08/2016 at 18:46 • 0 commentsI made the data glasses work, but it was more a trial an error challenge. So I took a google crash course in optics.
First of all I had to understand the difference between a real and a virtual image with lenses. Then a very important thing is, that a human eye can only focus an object with a distance of min 25cm.
And all what I needed was this formula (1/f) = (1/s2) + (1/s1) where f is focal length of the lens s1 is object distance to the lens and s2 is the distance of the virtual image.
I will build now Version III based on this calculation. -
Lens Update
07/05/2016 at 16:41 • 0 commentsToday the result of my lenses tests. All the easy to find lenses does not give the result I want.
The only one which works is the one from the video, the lens from a cheap Chinese 3d viewer.
Problem is, that I have no technical data about this one, what makes it difficult to rebuild the glasses for other users, so that I ordered 2 other models of lenses for testing. -
Lens and Screen mounted for Version B2
07/03/2016 at 19:34 • 0 commentsI found the time to try 2 lenses. Google cardboard lens and another one laying around here.
The google lens is not the best choice, so I will try a few other lenses
Here now the B2 version with lens and screen mounted. Works but I'm still not satisfied -
Version B2 with a focal point of 45mm
07/03/2016 at 16:15 • 0 commentsVersion II of my Arduino Glasses. Again build out of cardboard. Goes much faster than a 3d Printer (if I had one)
I added a sort of clip to attach it to the glasses. Hopefully I will add the lens and the screen this evening. -
New Design
07/02/2016 at 14:33 • 0 commentsNow it's sure, the Google cardboard lens has a shorter focal point. So I had to redesign my prototype and it seems to work. Need to cut the lens.
Lens differences
07/02/2016 at 11:16 • 0 commentsIt seems that the lens I used is not the same as the lenses in a google cardboard.
This is not what I wanted, I want to build this item that everybody can rebuild it.
I used for my first prototype, witch works, a lens from these cheap 3d glasses.
And this was the testsetup.
And now I has to redo the tests with original google cardboard lenses.
Testing an other optic version
07/01/2016 at 16:06 • 0 commentsThere is still a little ghost picture in the screen, so that I try another optic system. Looks better for the moment, but I have to change the lens -> screen setup.
Stunning Results
06/29/2016 at 17:59 • 0 commentsI searched and found a lens with f=45mm, and I trimmed it to the correct size.
I could not resist to test it instantly, and the result is stunning. I tried to photograph it, so that you can imagine the result.
