FreeCAD v 0.16 - 10X Objective Lens Holder Assembly
11/04/2016 at 08:39 • 0 comments3-D view of complete assembly of the 10X focal lens holder for the DAV5 V3 spectrometer. The holder has an attached rail [2mm width] rail slider that fits into the base, which allows for a 10mm total movement forward or backward in order to focus.
On the bottom which is depicted on the drawing, is an M3 mounting hole for a swivel insert in order to direct beam focus on second mirror.
Assembly CAD of the DAV5 V3 Spectrometer
11/03/2016 at 14:41 • 0 commentsPicture number 2, illustrates placement of first mirror and focal mirror at exactly 35 degrees for both mirror platforms, this conclusion was verified through my own experiments on my optics protoboard to make sure this design would work.
Now sometime in the future I may add a 10X objective eye piece lens in between the two mirrors if the focal mirror is not adequate enough to focus the wavelength correctly, or if I want to precisely choose a wavelength through incident angle diffraction.
So this is my rough draft number 1 ( without the lid of course.)
Design prototype enclosure for the DAV5 V3 spectrometer
10/31/2016 at 23:04 • 0 comments -
Rectangle Mirror Mount Design
10/29/2016 at 20:45 • 0 comments -
Re-designed Mirror Mount for The DAV5 V2 Spectrometer
10/29/2016 at 11:28 • 0 comments -
Testing Platform for the DAV5 V2 Spectrometer
10/27/2016 at 18:07 • 0 comments -
Custom Design Cuvette Holder DH4 V4a Spectrometer
10/27/2016 at 14:07 • 0 comments -
Revision 2 for Mirror Mount for DAV5 V2 spectromter
10/25/2016 at 12:50 • 0 comments -
Mirror Mount For The DAV5 V2 Spectrometer
10/25/2016 at 11:09 • 0 commentsThis is the design for the reflective and focusing mirror for the DAV5 V2, the mirror's are 25mm in dia. and 2.2mm in thickness, all parts will be 3-D printed for this project. The prototype as it stands right now, has a cost of $293.81 US, all tolerances as far as the designs go are 0.05mm +-, so I will have to see what the actual results turn out to be when the final parts are produced and make adjustments from there.
