Arduino 8-bit Computer
An emulated 8-bit computer based on an Arduino.
The main goal of this project is to learn about 8-bit computers and assembly code. I plan to emulate a custom 8-bit CPU and peripherals with an Arduino micro-controller. I will be using Z80 op-codes so that I can use an existing assembler. I would also like to find an easy method to transfer a Z80 binary file into the Arduino, but for now I'm just embedding the binary code into an array in the Arduino sketch. Ultimately, I would like this to be able to run any simple Z80 code. I'm currently running this on an Arduino Uno, but I will likely end up using an Arduino Mega board.
Many op-codes have not been included yet, however there are enough to write some simple programs.
I will try to have an example for every op-code.
Examples:
Load: Put a 3 in register A
Mnemonic:      Op-code:
LD A,3             0x3E, 0x03
Add: Add 2 to 5
Mnemonic:    Op-code:
LD  A,5           0x3E, 0x05
LD  B,2           0x06, 0x02
ADD  A,B       0x80
Subtract: Subtract 3 from 5
Mnemonic:   Op-code:
LD  A,5          0x3E, 0x05
LD  B,3          0x06, 0x03
SUB B            0x90
  • 1 × Arduino Uno
  • Memory successes and problems.
    Ryan Gass06/26/2014 at 18:05 0 comments
    The emulator  now lets code access the SD card using I/O instructions. One of these instructions tells the Arduino to load a binary file into the emulated memory. This is nice, however the memory array is stored in RAM, so it is very limited in size. I will likely switch to using flash instead.
  • It works!
    Ryan Gass05/26/2014 at 19:53 0 comments
    I was able to blink the LED on pin 13 using my emulator and Z80 compatible op-codes.
View all 2 project logs
Marcelo Dantas wrote 12/29/2014 at 16:58 point
Hi Ryan, have you tried SPI RAM? I have written a similar emulation for the Arduino DUE (no memory shortage there), but I am planning to migrate it to the Teensy 3.1, using external SPI RAM. Theoretically it could be done by the UNO as well.
Ryan Gass wrote 01/03/2015 at 03:50 point
It should be able to use anything that you could map to an array. I haven't worked on this for a while, but I've been thinking about using the EEPROM for ROM so you could just burn a HEX or BIN file into the EEPROM.
bijtaj wrote 06/26/2014 at 19:05 point
How are you programming it? using your computer? Will you have an LCD screen?
Ryan Gass wrote 06/26/2014 at 21:09 point
I am using zDevStudio on my computer to generate a bin file that I put on the SD card. The Arduino loads the bin file off the SD and runs it. I have a LCD shield that I plan to add to it.
