The Big Test: Curling 170lb (80kg)
08/30/2014 at 12:57 • 0 comments![]()
Preparing for the Big Test
08/30/2014 at 12:48 • 0 commentsSo unfortunately, I don't own weights to test this thing out... I'm thinking I'll try and make some concrete ones -- or as a fall back plan, just use cinder blocks.
Okay so making concrete ones didn't work out so well -- cinder blocks will have to do.
Last minute preparations before the big test...
Let's test it again!
08/30/2014 at 12:46 • 0 commentsAlright so I've got the one arm mounted to the frame -- let's see how she works!
Seems to work pretty good... Let's make the other arm and mount it all together!
Putting it all together
08/30/2014 at 12:43 • 0 commentsLet's put it all together!
A Question of Joints
08/08/2014 at 10:51 • 0 commentsOne of the trickiest parts of this build will be keeping the exoskeleton flexible, so I've been looking at using Ball Joints (Spherical Rod Ends or Heim Joints). But can I combine two together to make a joint with more flexibility?
Building the Frame
08/08/2014 at 10:49 • 0 commentsSo to mount this thing on me I can't exactly copy the real Elysium design... not crazy about installing screws into my skeleton...
I was trying to figure out a way to make a frame that can support a large weight so I looked at camping backpack frame designs... Perfect. But we're going to have to make one out of steel to make it a bit stronger. -
Planning and Design
08/08/2014 at 10:46 • 0 commentsTime for some planning before we get too far ahead of ourselves!
Successful Lift!
06/16/2014 at 12:37 • 0 commentsIt works! We're currently running it at 100PSI and even at that pressure it is capable of curling a battery that weighs 67lbs!
These cylinders are rated for 250PSI, so hypothetically we could lift over 150lbs! Per arm! -
The First Test!
06/16/2014 at 12:34 • 0 commentsThis is exciting -- let's test out the arm!
Testing out the Pneumatic Cylinders
06/16/2014 at 12:32 • 0 commentsNow that I have a rough idea of what I'm doing, let's test out some of the components!
James Hobson
