spec.ui
Here is the code for the actual pyqt GUI. Put it in the same directory as the pyqt_spec_ser.py code. Not in final form, but it works for testing.
x-designer -
2.78 kB -
10/03/2017 at 01:18
Download
pyqt_spec_ser.py
This is the Python code for running the Spectrophotometer. It runs on a Linux box, but can be easily modified to run with Windows. Only the command to open the serial port needs to change. This assumes that the LockIn_Spectro2.ino code is running on the Teensy. Not pretty, not final, but works for anyone who wants to play or just see the code.
x-python -
4.69 kB -
10/03/2017 at 01:15
Download
LockIn_Spectro2.ino
This is the Arduino file for controlling the Teensy. This code is not well commented or especially pretty, but I provide it for those who really want to see how to control the ADA2200 and the other parts of the system.
ino -
11.28 kB -
10/03/2017 at 01:11
Download
MovingBlade.fcstd
Slit Movable razor blade holder in FreeCAD format.
x-extension-fcstd -
71.32 kB -
01/06/2017 at 01:32
Download
MovingBlade.stl
Slit Movable razor blade holder in stl format.
sla -
637.09 kB -
01/06/2017 at 01:31
Download
Anchor.fcstd
Slit Adjusting Bolt Anchor in FreeCADformat.
x-extension-fcstd -
17.92 kB -
01/06/2017 at 01:31
Download
Anchor.stl
Slit Adjusting Bolt Anchor in stl format.
sla -
330.16 kB -
01/06/2017 at 01:30
Download
FixedBlade.fcstd
Slit Fixed razor blade holder in FreeCAD format.
x-extension-fcstd -
24.95 kB -
01/06/2017 at 01:30
Download
FixedBlade.stl
Slit Fixed razor blade holder in stl format.
sla -
181.04 kB -
01/06/2017 at 01:30
Download
Parts List.pdf
Parts lists for the Lock-In Amplifier and the LED Supply. Has Digikey part numbers, descriptions, and package.
Adobe Portable Document Format -
53.32 kB -
08/11/2016 at 04:21
Preview
SpectromLEDSupply.sch
Spectrometer LED constant current supply schematic in KiCAD format.
x-kicad-schematic -
22.82 kB -
07/09/2016 at 23:25
Download
SpectromLEDSupply.kicad_pcb
Spectrometer LED constant current supply pcb in KiCAD format.
kicad_pcb -
65.83 kB -
07/09/2016 at 23:25
Download
SpecLEDSupplySchematic.pdf
Spectrometer LED constant current supply schematic as a pdf for easy viewing.
24.94 kB -
07/09/2016 at 23:25
Preview
Lock_In.kicad_pcb
Lock-In Amp pcb in KiCAD format.
kicad_pcb -
140.35 kB -
07/09/2016 at 23:22
Download
Lock_InSchematic.pdf
Lock-In Amp schematic ias a convenient pdf.
77.69 kB -
07/09/2016 at 23:22
Preview
Cuvette1.stl
Cuvette holder in stl format
sla -
124.59 kB -
07/09/2016 at 23:22
Download
Cuvette1.FCStd
Cuvette holder in FreeCAD format.
x-extension-fcstd -
52.67 kB -
07/09/2016 at 23:22
Download
Lock_In.sch
Lock-In Amp schematic in KiCAD format.
x-kicad-schematic -
39.38 kB -
07/09/2016 at 23:22
Download
Cover.stl
Cuvette holder cover in stl format.
sla -
41.49 kB -
07/09/2016 at 23:22
Download
Cover.FCStd
Cuvette holder cover in FreeCAD format.
x-extension-fcstd -
13.84 kB -
07/09/2016 at 23:22
Download
