Low cost 3D 64 Pixel TOF camera
I get my raw TOF sensors, and i ask me if i can solder it, The pitch is 0.45 mm. I knew this sensors are small - but to see it...
Next steps are:
selecting Components
electrical and optical
PCB design ......
My question is : from where can i get cheap fixfocus glass lenses?
The type used in piCamera module could be usable if glass lenses are used.
Anyone could give me some info where i can find?
hi Frank.Muenzner the chip very cool . what's chip had any more information about the chip . maybe the chip seem or same design : http://www.polytec.com/fileadmin/user_uploads/Products/Optoelektronische_Komponenten/Sensoren/Documents/PH_OEK_Espros_Datasheet_epc610-V1_7.pdf
Thank you very much Eric,
i contacted the supplier for mechanical drawings, the parts will be ordered in the next days.
here is a lens that is similar to what you asked for.
have you seen https://onion.io/
Tau LiDAR Camera
An easy-to-use LiDAR camera that acts like a webcam for real-time 3D depth data
