This is pretty straightforward. There are a number of online tools to allow you to do this. I used http://www.autotracer.org/. This site allows you to upload the URL of the image you would like to render and then save the file. Then I used Autodesk's online DXF viewer to view the image before sending it to a laser cutter.
Went to my local Menard's and Hobby Lobby to pick up some card stock and acrylic. Picked out some cutters just in case I couldn't get access to a laser cutter.
This is pretty self explanatory. Type "Team Valor" into Google Images and find a log that you can use (give credit to images where credit is due). I found Jack Loupe's rendering on his blog. https://jackaloupe.com/2016/07/06/team-valor-logo-cutout/
Since Pokemon GO came out, I've wanted to make something to related to the game. I wanted something I could make in an afternoon that I could use right away, so I thought of a blinking Team Valor badge to represent the best team in Pokemon GO. The circuit is simple, I am using a square wave oscillator that is driving an NPN transistor which lights the LEDs. The real challenge comes in the enclosure. I laser cut a cut-out of the Team Valor Emblem and glued it to one side of a piece of non-glare acrylic. When the LEDs turn on, the emblem is displayed in all its glory.
2
Step 2
All the materials should run you about <$10 (minus the laser cutter of course and soldering tools)
1 x Team Valor Emblem -- Moltres cut-out on black cardstock 1 x 3 in by 3 in piece of acrylic 1 x acrylic cutting knife 1 x 2 in by 2 in piece of aluminum foil 1 x 2 in by 2 in piece of white paper 12 x 5mm LEDs 2 x MCP6002 Op Amp 4 x 10k resistor 3 x 100nF capacitor 1 x 3.3M resistor 1 x perfboard Copper tape Hot glue Tape measure Soldering tools Laser cutter
3
Step 3
This part will be really easy if you have a laser cutter. I found an image of the Team Valor Emblem online on Jackaloupe's blog and then used an online image to .DXF (common file type for CAD drawings) converter to prepare the image for the laser cutter. Then I uploaded the DXF file to a laser cutter I have access to at school and viola! We have our Moltres cut-out.
If you do not have access to a laser cutter, I would suggest a hobby knife and transparency from your local Hobby Lobby.
