Swapping to Ni Mh Battery
07/17/2016 at 16:55 • 0 commentsNow changing to a Ni Mh Battery allows a bit more current and makes the cleaninator even faster
Creating 2 prototypes
07/17/2016 at 16:53 • 0 commentsIn total 2 prototypes were built, 1 by E (14y old), and 1 by B (11y old).
the first one rotates a lot and moves slowly. This may be excellent for thorough cleaning.
the second one moves fast and doesn't rotate.
The difference is in the weight balancing, in positioning the battery holder and motor,
and in the selection of the asymmetric load.By choosing the position, you can physically 'program' the robot behavior.
Here is a video comparing the behavior of the 2 prototypes :
Glueing it all together
07/17/2016 at 16:40 • 0 commentsGlued it all together, it looks good !
Clean up the excessive glue
Testing before build
07/17/2016 at 16:38 • 0 commentsFirst tests were done with a motor on the table.
