Initially this project came about as the device stopped working. Assuming the circuitry as its about 30 years old, i started working towards replacing it with an arduino to process the sensor signal into output for the speed needle.
But during testing it started working, so im putting this on hold.
hayden
Vinch
Rajendra Bhatt
Had a mechanical one with a cable. Hands on a sumlog 2 and will convert it to an electric one. The sumlog 2 gear disintegreted. So I will 3 d print a gear.
Reinier
