Blah.............................
06/04/2014 at 03:06 • 0 commentsWell, that didn't go well :( Apparently my Canon printer doesn't work well for toner transfer. Going to try one of the HP printers at the office tomorrow.
PCBs - Let the adventure begin.......
06/04/2014 at 00:52 • 0 commentsSo, this is my first attempt at home etching a PCB. I'm attempting to use the toner transfer method using magazine pages. The method itself seems to be sound, I'm just having trouble getting my print settings correct (SCREW YOU ADOBE!!!). Once I get a decent transfer onto the PCB, I'll be using the muriatic acid and hydrogen peroxide method of etching. Wish me luck!
Enclosure
06/02/2014 at 21:02 • 0 commentsAlso wanted to mention something else on the to-do list. As this controller deals with live household current, it should definitely be contained in an enclosure when in use. So, in addition to what I am already working on, once I have the PCB design finalized, I will also design a 3D printable enclosure. As I already have a 3D printer, this makes more sense than trying to fit the assembly into a stock project enclosure.
Firmware Revision .01 - UNTESTED!!!
06/02/2014 at 20:35 • 0 commentsJust hammered out revision .01 of the firmware for this controller. There will be an update to the hardware design files as well once I have time to add in at least a couple of inputs (on/off and autotune), and possibly an LED output. This firmware is currently untested as I am waiting for the components to show up to actually build the circuit. Next step will be to etch a prototype PCB once I finish tweaking the design file. This will be my first attempt at etching PCBs, so that should be an adventure in and of itself :)
Zero Cross Detection Testing
05/30/2014 at 12:44 • 0 commentsSpent a little time with my Arduino and a breadboard last night testing the zero cross detection circuit. I was a little skeptical as to whether this would work, even though I found out about it through an Atmel datasheet. However, it works as advertised. I do not have a local source to acquire a the necessary triac from, so I will have to wait till it shows up from Mouser before I can test the output side of the circuit. That should give me time to get started on writing the code. Once I have some code going to work with, I should be able to do some testing with a logic analyzer to verify that the triac trigger signal is happening when it is supposed to in relation to the AC phase.
**********WARNING*************
Also, as mentioned before, if you are not familiar and/or comfortable working with live household current, DO NOT ATTEMPT THIS PROJECT
