Full instructions now available!
01/28/2018 at 12:01 • 0 commentsFull instructions now available at:
https://www.instructables.com/id/Joy-Robot-Rob%C3%B4-Da-Alegria-Open-Source-3D-Printed-A/
Roadsec 2017
11/18/2017 at 12:06 • 0 commentsJoy Robot was at Roadsec 2017, the greatest hacker faire of Latin America!
O Robô da Alegria foi apresentado na Roadsec 2017, a maior feira hacker da América Latina!
3D printed body
11/06/2017 at 18:42 • 0 comments -
Mounting robot's head
08/29/2017 at 20:12 • 0 commentsThe head of the robot was divided in eigth 3d printed parts, all of them printed in PLA with 0,2mm resolution, 10% infill and no supports. It took almos 15 hours for printing the 130 mm in diameter structure.
The top and bottom of the head were divided in two parts and glued. All the other parts are mounted using screws, so that the head can be disassabled for repair.
Four 8x8 LED matrix were used on robot's face.
A cabeça do robô foi divida em oito partes impressas em 3d, todas elas em PLA com resolução de 0,2mm, infill de 10% e sem suportes durante a impressão. Foram necessários quase 15 horas para impressão da estrutura com 130 mm de diâmetro.
O topo e a parte de baixo da cabeça foram divididos em duas partes e colados. Todas as outras partes são montadas usando-se parafusos, de forma que a cabeça possa ser desmontada para manutenção.
Quatro matrizes de LED de 8x8 foram usadas na face do robô.
3D printed helmet
08/14/2017 at 19:05 • 0 commentsThe head of the robot was designed in Fusion 360. It's composed of 6 parts, which were printed in white PLA with 0.2mm resolution. Total printing time: 14 hours.
A cabeça do robô foi projetada usando o Fusion 360. Ela é composta de 6 partes, as quais foram impressas em PLA branco com 0,2mm de resolução. Tempo total de impressão: 14 horas. -
3D miniature
07/13/2017 at 15:50 • 0 comments -
3D printed miniature
06/30/2017 at 13:49 • 0 comments5 cm tall 3D printed miniature of the robot with articulated arms.
Printed in PLA, 0.2mm layers, 20% infill.
Miniatura de 5 cm de altura do do robô com braços articulados impressa em 3D.
Impresso em PLA, com camadas de 0,2 mm e 20% de preenchimento.
oneDay 2016
10/24/2016 at 15:33 • 0 comments -
Robot's structure
10/12/2016 at 15:55 • 0 commentsComparison between digital design and physical prototype:
Comparação entre o projeto digital e o protótipo físico.
oneDay 2016 - Full presentation (subtitled)
10/05/2016 at 18:22 • 0 comments
