Improving the process
11/07/2014 at 08:44 • 0 commentsI am re-building the lamp from scratch and making some improvement to every steps, taking picture, and updating the instructions.
The two best improvement for now are:
- Using polyimide adhesive tape to maintain the components in place while soldering (that I later re-improved by putting the adhesive tape on top of component after they have been aligned instead of trying to align them directly on the tape)
- Using potentiometer to choose andmeasure the needed resistors instead of trying some complicated graphs and use fixed value resistors to validate.
Featured on HaD.io !!!
06/20/2014 at 19:00 • 0 commentsAfter this project has been featured on HaD.com, its now on the first line on HaD.io !! I'am really glad that HaD team likes all the time i spent documenting this project.
I am currently in Moroco for a friend's wedding, but will update the project soon. I found the perfect easy and cheap solution to solder the smds, and am now trying to find the perfect way to solder them on the 1.5mm copper wire that dissipate all the heat from my soldering iron, then there will be no more rechniczl dificulties and I will probably finish the documentation in the next two weeks !
THanks to the people who like and follow the dna lamp project, it really makes it a bit more magical than it already was.
fabien.
ps : i lost my netbook psy and try to use an ipad to write this post.... Sorry for typos.
Testing materials for soldering jig
06/10/2014 at 11:42 • 0 commentsMy first prototype has been made without soldering jig. It works, but looking from a close range you can see the component does not have a perfect alignment.
For now, I tested the following material:
-Marble is not that good. Even with a good polish, solder then to stick to it.
-PTFE (teflon). I could not find some 0.5 or 1mm teflon sheet, so I tested with PTFE thread seal tape wrapped on some 2mm aluminum bar. It works: teflon stick a little bit to solder, but is easy to remove with tweezers. But my 2mm aluminum bar does not have sharp enough corners. Since the components are so thin (0.5mm for the resistors I bought, leds are even thinner) I would need a really sharp corner with thin ptfe tape to get a really good result. Anyway it is working.
-I've been given some 1mm polyimid (kapton) sheet. That seems to work fine but kapton is so slippery... I need to find something to hold the parts of the jigs in place. High temperature glass glue would be fine but mine is too old and I don't want to buy tome more. I could make holes and use 2x2mm metal cylinders to fix the sheets, but polyimid sheets are not easy to buy and I may try to find something else for this tutorial. I ordered adhesive polyimid tape to give it a try.
-Microscope slides can be a good alternative to marble (1"x2"x glass), I'll try to buy some next time I go near a lab supply shop.
-Wood is not that bad, but you have to find a particular piece of wood that will not wrap when put in oven at 280°C for one minute.
Featured on HaD!
06/05/2014 at 13:12 • 0 commentshttp://hackaday.com/2014/06/04/helix-turning-tool-born-from-necessity/
That's certainly turned today into a good day :)
As you know, I had some problems with some steps being duplicated, apparently overwitting the last steps I wrote. I wanted to let the mess as it for HaD Project team to investigate, but when I saw my project featured, ... I hade to clean everything and re-put steps in proper order.
Lost one hour of work :(
06/04/2014 at 09:35 • 0 commentsSomething wrong happen when I was saving the last step I wrote in the instructions... now all steps I wrote this morning and are missing :(
I don't even know what exactly is missing, nor if I kept all the pictures.
I wrote an email to hack a day project team, I hope they can find the text somewhere in their database...
Matching leds intensities
06/03/2014 at 09:39 • 0 commentsI played with my leds this morning to see how much current each color sould get in order to have homogenous luminosity. Here are my results:
Unfortunately, photos of leds are never as nice as reality
(if you wonder how I soldered the leds, see my tutorial here )
Breadbording 0603 components
06/02/2014 at 18:22 • 0 commentsI needed to make a current vs tension graph of the leds I ordered, but unfortunately the cheap hook I had did not do a great job on so tiny and light component.
Fortunately, I ended up with a solution I like.
See it there if you want: http://hackaday.io/project/1300-Easy-breadbording-of-0603-SMD-components
Taking picture for this project
06/01/2014 at 11:46 • 0 commentsI need a macro extension ring. My "macro" Canon EF 28-70/2.8L just can't take a good picture of a 8x0.8mm led string, even after cropping.
I order a lens and body cap pair for cheap on aliexpress, hoping to glue them together to make a macro extension ring for cheap.
For now, my solution is to put a cheap 65mm magnifying glass as close as possible to the front lense of the 28-70. Image quality is not that good but it works.
Old (and expired) credit card just there for size reference. '480' was not part of any information you needed to use this card before it expired ;)
The Good Enough Helix Winder
06/01/2014 at 11:44 • 0 commentsLots of tutorials/videos on the internet show you how to roll your own springs. Though the produced spring are useful, in the DNA Lamp the two helix will be intertwined we need them really regular. If one turn is 0.2mm longer than expected, when the corresponding turn on the other helix is 0.3mm shorter, the 0.5mm corresponding misalignment will give a "not so cool" feeling.
After some tries (read: fails), I manage to make a cheap, easy to build, manual helix winder that gives good enough results. I named it Good Enough Helix Winder, but don't know how to pronounce GEHW.
