The Ultimate 3D Printer
Here I update you how I am upgrading and making my Printrbot Simple Metal better and easier to use
I received my Printrbot Simple Metal in the summer of 2015 and since then I have been having a great time. Though my experience has been fun, I want to fix issues that will make my experience better and give my printer some personality.
h
  • 2 × VoltMeter To measure the amount of voltage my printer is using
  • 4 × Switches To turn of the printer and fans
  • 1 × Wire To hook up compents
  • 100000000 × Various M3 Screws 10mm, 16mm, 30mm and 50mmm mainly used
  • 100000000 × M3 Nuts and Washers
View all 10 components
  • Octoprint
    Shivam Mehta • 08/06/2016 at 14:48 • 0 comments
    If you're familiar with 3D printing, then you must've heard of Octoprint. Octoprint takes your raspberry pi and creates a local server for your printer so you can print from any web browser. You can also hook up a camera so you can see your print from anywhere. I am not going to show you how to setup because there amazing tutorial out on youtube. I used a raspberry pi 3, raspberry pi camera, sd card, micro usb cable and wifi dongle to complete this project.
    For the case, I needed something mounted on the bed because the camera cable is short and the camera needs to be mounted on the bed.
    Case: http://www.thingiverse.com/thing:673133
  • Little Upgrades
    Shivam Mehta • 07/31/2016 at 02:46 • 0 comments
    Printing Little things for your printer from the start can change your whole experience in how you use your printer every day.
    FINGER FLOBBER
    If your someone like me who is constantly changing filament and this is NEEDED for your printer. They are many designs that solve this problem but this one in particular is the most elegant and I am also able to cool my extruder without anything being in the way.
    Link: http://www.thingiverse.com/thing:446480
    Printrbot Fan Duct
    Just like the last one, there are many fan ducts out there and one is probably the best one out there. It flows the air around the extruder so it can cool the print opposite to the fan.
    Link: http://www.thingiverse.com/thing:356001
    Chain Link
    This upgrade is not the most necessary but is a good idea. This upgrade it to avoid the wire harness from touching the heated bed and any strain the wires are having.
    Link: http://www.thingiverse.com/thing:1060522
    With all these upgrades, your experience with printer will be a lot easier and you will for sure have better print results.
View all 2 project logs
FrankenPC wrote 08/24/2016 at 20:42 • point
WiFi is onboard the Raspberry Pi 3.  Why the dongle?
Erin RobotZwrrl wrote 08/04/2016 at 14:07 • point
Nice! Can't wait to see the other upgrades you've done to it... gotta love the Printrbot Simple Metal!
Also 100000000 M3 screws required... but what if I lose one?!?!?! :) haha
