Framing the window and door liners in the 20in/508mm thick double wall construction
JPEG Image -
3.31 MB -
05/21/2018 at 02:43
Preview
into woodworking jigs, and more jigs, table saw safety and more seumas2 has about 400 videos on viyoutube
JPEG Image -
308.45 kB -
04/14/2018 at 00:06
Preview
used a straight edge with the router
JPEG Image -
607.21 kB -
04/14/2018 at 00:05
Preview
simple INNOVATIVE router idea by George K
JPEG Image -
524.57 kB -
04/14/2018 at 00:02
Preview
used a router with an 1in./25mm bit to channel in the water lines, blue coded for the cold/ red coded for the hot
JPEG Image -
643.29 kB -
04/13/2018 at 23:59
Preview
passive 66 003.MTS
video shows how the insulation under the concrete pad is laid and sealed to R 50 plus
mpeg-tts -
32.44 MB -
04/12/2018 at 22:16
Download
00001.MTS
base for the foundation pad, setting the rough plumbing lines
mpeg-tts -
27.19 MB -
04/12/2018 at 01:35
Download
00000-003.MTS
3 ft by 6in footing, 32in by 8in foundation walls, 915mm by 152mm, 812mm by 202mm, insulation on the pad is R- 50
mpeg-tts -
24.94 MB -
04/12/2018 at 01:21
Download
