VoCore + WeMo ebb N flow hack
08/22/2016 at 00:54 • 0 commentsWeMo Insight Switch
Cost: $49.99 (Amazon.com)
VoCore: $39.99
Control: WeMo App
My goal turn the WeMo on for 10mins
to drains the tables into the pond.
Then turn it off for 20mins to ebb the deep water beds.
Repeat 24hrs per day.
WeMo required start on the hr then auto-shut off.
24 hrs - 24 Timers in the Wemo App.
Not going to work.
Solution,
1. Join VoCore to My WiFi Network
2. Connect via ssh
3. Install python on VoCore (OpenWRT)
4. Download WeMo python app
5. Setup bash script to turn on the flow
& hold the ebb (Outputs to a txt log)
6. Test
7. Deploy
Garden Blog
08/07/2016 at 03:28 • 0 commentsAll the aquaponics changes and plants are photo logged to
https://froggyfarms.com/index.php/category/gardens/1915_16/ -
Crop Tracking
08/07/2016 at 03:21 • 0 commentsTo keep track of what is in the garden, I am using crop planning by clayton carter.
To keep as much portable as possible, I have built out a Debian net install VM in VirtualBox.
Added lxde gui - VM auto launches logs in and starts crop planner.jarI use the VMs as they allow simple fast way to transfer whole machine solution to AWS.
https://github.com/onerealfunnyguy/cropplanning
/cropplanning
Recycled phone Video Streaming
08/06/2016 at 23:27 • 0 commentsVideo Monitoring of fish & frog tanks.
Using old android phones (root not required) add 24hr video recording.
Solution:
VM / Physical Server - Open Media Vault : http://www.openmediavault.org
Used for local video store
VirtualBox: https://www.virtualbox.org
VM OS ubuntu: http://www.ubuntu.com (Easy OBS install)
VM - OBS : https://obsproject.comUsed to stream to youtube.com / blog
Android App (Install on old phones)
IP-WEBCAM: http://ip-webcam.appspot.com
Ubuntu VM recording to OMV & streaming to youtube.comYoutube feed embedded into blog post.
IP-WEBCAM provides the internal video feeds that OBS works with.Using hotkeys in OBS & a bash script the feeds are auto switched inside OBS
https://froggyfarms.com/index.php/2016/07/24/env-monitoring/
Tracking sensor data
08/06/2016 at 23:25 • 0 commentsAdd apps to steam sensor data.
Add adb Wireless (no root) to access phones remotely from cli.
https://play.google.com/store/apps/details?id=za.co.henry.hsu.adbwirelessbyhenry
Added WeatherSignal it write sensor readings to CSV
https://play.google.com/store/apps/details?id=com.opensignal.weathersignal
Add Autosync Google Drive transfer WeatherSignal CSV to Google Drive
https://play.google.com/store/apps/details?id=com.ttxapps.drivesync
