Project Progress #5
06/13/2018 at 14:06 • 0 commentsHi guys !
One day left before the exhibition of our project and we are pleased to announce you that we succed !
At the very beginning we wanted to create a device that changes the intensity of a light depending of the exterior light ! And that's what we got now.
I will show you quickly the aspect of the project without his box and you'll see the box in few days.
Here is the final montage that will be detailled very soon. You will be able to create an adaptive lightning thanks to our instructions.
Here is the project working.
Project Progress #4
05/30/2018 at 19:24 • 0 commentsHello again!
we have finally made some noticeable progress in our project. After a lengthy discussion with our supervisor, he advised us to try and make a our concept work a single led, and guess what IT WORKS !
it took us some time but we eventually were able to figure it out. the pictures above and bellow show the circuit we built and used.
We also came up with the code which we will share soon on our next log.
Project Progress #3
05/24/2018 at 08:34 • 0 commentsHere is the repost of the log from 17/05/2018 :
Today we figured out that for our project we would use PWM (Pulse With Modulation) to synthesize our continuous signal.
In order to connect our LED strip to the Arduino we need to reproduce the following image.
Project Progress #2
05/17/2018 at 09:18 • 0 commentsHere is the repost of the log from 05/03/2018 :
Hi guys !
The components we ordered finally arrived :
- a light sensor
- a LED strip
- an arduino "Leonardo"
- a 10 Kohm resistors
- transistors
- a 12V 2A Power supply
We also started making the arduino program conected to the light sensor. The program we have recognize the intensity of ambient light and tells us if it is :
- Dark
- Light
- Luminous
- More luminous
- Very bright
We now have to deal with a mean to connect the LED strip to the arduino and modify our code to change the intensity of led light according to ambient light.
See you !
Project Progress #1
04/29/2018 at 16:21 • 0 commentsHey guys !
We will start our project in an experimental way.
The theoretical part is very well advanced and we now know in which direction to start.
This project is very interesting although complex but we are convinced that within 1 month we will be finished.
For now we are looking forward to receiving the components and getting to work.
See you very soon !
Lucas BROGLIO
