1Step 1
Configure and Assemble the TPS
- Open LTPS Web Interface by simply entering its IP address in your browser, select the "Tibbits Layout" tab, and push the "Launch TPS Configurator..." button.
![LTPS Web Interface]()
Setup Tibbits Layout as shown on the screenshot below and click File/Save
Note: TPS needs to be rebooted to take new Tibbits Layout into effect.
![Proposed tibbits layout]()
- Assemble TPS according to the Tibbits Layout
Attention: it's strongly recommended to shut down TPS before placing/removing Tibbits.
![Assembled device with the top cover removed]()
2Step 2
First application
Node.JS, Git and Python 2.7 are installed on each LTPS by default, but NPM is not.
- For installing, connect it to your device with SSH and do the following:
# Setup package repositories smart channel --add 150a type=rpm-md name="LTPS all" baseurl=http://tibbo.com/downloads/LTPS/packets/all/ -y smart channel --add 150c type=rpm-md name="LTPS cortexa" baseurl=http://tibbo.com/downloads/LTPS/packets/cortexa8hf_neon/ -y smart update # Install NPM smart install nodejs-npm -y
then# Create folder for application cd /opt/node-apps/ mkdir environment cd environment # Install required modules npm install @tibbo-tps/tibbit-28 npm install @tibbo-tps/tibbit-30 npm install @tibbo-tps/tibbit-35
/opt/node-apps/ folder is proposed to be used for your Node.JS apps.
- In any IDE or even a text editor create azure-app-0.js file with you application:
var tibbit28 = require("@tibbo-tps/tibbit-28").init("S11"); var tibbit35 = require("@tibbo-tps/tibbit-35").init("S13"); var tibbit30 = require("@tibbo-tps/tibbit-30").init("S15"); setInterval(function(){ var illuminationData = tibbit28.getData(); var humidityData = tibbit30.getData(); var pressureData = tibbit35.getData(); var dateTime = new Date(); console.log("Date/Time: "+dateTime); console.log("Illumination: "+illuminationData.illumination); console.log("Humidity: "+humidityData.humidity); console.log("Temperature: "+humidityData.temperature); console.log("Pressure: "+pressureData.pressure); },1000);- Upload it to /environment folder and run:
$ node azure-app-0.js Date/Time: Tue Jul 19 2016 13:50:54 GMT+0000 (UTC) Illumination: 115 Humidity: 43.755340576171875 Temperature: 28.05670928955078 Pressure: 738.7398681640625
3Step 3
Setting Up Microsoft Azure IoT Hub
Microsoft Azure IoT Hub is a service that allows bi-directional communications between your devices and a solution back end. To complete this part of the tutorial you'll need:
- TPS device(s) prepared as shown on the Step 0
- An active Azure account
- A PC with installed Node.js
Create an IoT Hub
- Sign in to the Azure Portal
- Choose New > Internet of Things > Azure IoT Hub
- Configure your IoT Hub, then click "Create"
![Azure Portal: Creating an IoT Hub]()
- Wait a few minutes until your IoT Hub has been created then select All Resources > [name of your IoT hub] and click "Keys" icon.
- In the Shared access policies blade select the "iothubowner" item and then copy the value of "Connection string" field.
![Azure Portal: Setting up your IoT Hub]()
4Step 4
Registering Device Identities
There are three ways to register device identities: with a script using Azure API, with GUI App (for Windows only) and with multiplatform CLI tool. The third way seems to be the most convenient one.
Note: To use iothub-explorer you need Node.js version 4.x or later installed
- On your PC run:
npm install -g iothub-explorer@latest
- then:
$ iothub-explorer login Session started, expires Thu Jul 21 2016 13:22:10 GMT+0400
where <connection-string> is an iothubowner connection string from Step 2.
- To register a new device and get its connection string:
$ iothub-explorer create <device-name> --connection-string Created device tps-centreville ... connectionString: HostName=iot-tps.azure-devices.net;DeviceId=tps-centreville;SharedAccessKey=fSCVQIY..TOprSsDE=Where <device-name> is e.g. "tps-centreville".
- Make note of the connections string.
5Step 5
Making devices IoT-enabled
- Connect with SSH to the TPS, change folder to /environment and do:
npm install azure-iot-device npm install azure-iot-device-amq
- Create azure-app-1.js file with the following app:
var clientFromConnectionString = require('azure-iot-device-amqp').clientFromConnectionString; var Message = require('azure-iot-device').Message; var connectionString = '<THE DEVICE CONNECTION STRING FROM STEP 3>'; var client = clientFromConnectionString(connectionString); var tibbit28 = require("@tibbo-tps/tibbit-28").init("S11"); var tibbit35 = require("@tibbo-tps/tibbit-35").init("S13"); var tibbit30 = require("@tibbo-tps/tibbit-30").init("S15"); client.open(function(err){ if(err){ console.log('Could not connect: ' + err); }else{ console.log('Client connected'); setInterval(function(){ var illuminationData = tibbit28.getData(); var humidityData = tibbit30.getData(); var pressureData = tibbit35.getData(); var time = new Date().toISOString(); var data = JSON.stringify({ deviceId: 'tps-centreville', humidity: humidityData.humidity, temperature: humidityData.temperature, pressure: pressureData.pressure, illumination: illuminationData.illumination, time: time }); var message = new Message(data); client.sendEvent(message, function (err) { if(err){ console.log(err.toString()); }else{ console.log("Message sent: " + message.getData()); } }); },60000) } });- Upload it to /opt/node-apps/environment folder on the TPS and run:
$ node azure-app-1.js Client connected Message sent: {"deviceId":"tps-centreville","humidity":37.1016960144043,"temperature":31.370407104492188,"pressure":742.8632202148438,"illumination":136,"time":"2016-07-21T10:19:07.490Z"} Message sent: {"deviceId":"tps-centreville","humidity":37.1016960144043,"temperature":31.370407104492188,"pressure":743.2034301757812,"illumination":137,"time":"2016-07-21T10:20:10.582Z"} Message sent: {"deviceId":"tps-centreville","humidity":37.1016960144043,"temperature":31.380477905273438,"pressure":743.2034301757812,"illumination":138,"time":"2016-07-21T10:21:12.003Z"}Event monitoring is the most remarkable and very useful feature for the purpose of debugging iothub-explorer. With iot-explorer, you can easily observe events sent by your devices to cloud and vice versa.
Note: this command requires providing iothubowner connection string even if you're already logged in.
- On your PC do:
$ iothub-explorer monitor-events tps-centreville Monitoring events from device tps-centreville Event received: { deviceId: 'tps-centreville', humidity: 37.1016960144043, temperature: 31.380477905273438, pressure: 743.2034301757812, illumination: 138, time: '2016-07-21T10:21:12.003Z' }You can see every event as soon as it's sent to IoT hub. -
6Step 6
Configure Stream Analytics
Note: To compelete this part of the tutorial you'll need an active Microsoft Power BI subscription.
Before the information can be delivered to Power BI, it must be processed by a Azure Stream Analytics job.
- Choose New > Internet of Things > Stream Analytics Job
- Configure the Job, then click "Create"
- Wait a couple of minutes until the Job has been created, then select All resources > name of your Stream Analytics Job
- Click Inputs > Add
Set up input in the following way:
- Input alias : data-from-tps
- Source Type : Data stream
- Source : IoT Hub
- Subsriptiopn : Use IoT hub from current subscription
- Endpoint : Messaging
- Shared access policy name : iothubowner
- Consumer group : powerbi
- Click "Create"
Set up output:
- Output alias : data-to-powerbi
- Click Otputs > Add
- Choose Power Bi as sink
- Click Authorize and enter your Power BI credentials in the appearing window
- Enter Dataset Name and Table Name, e.g. "telemetry" and "environment", respectively
- Click "Create"
Now it's time to enter the query:
- Click Query
- Enter the following:
SELECT AVG(humidity) AS humidity, AVG(temperature) AS temperature, AVG(pressure) AS pressure, AVG(illumination) AS illumination, System.Timestamp AS time, IoTHub.ConnectionDeviceId AS deviceId INTO [data-to-powerbi] FROM [data-from-tps] TIMESTAMP by time GROUP BY TumblingWindow(Second, 60), IoTHub.ConnectionDeviceId- Click Save
Stream Analytics Query Language is a subset of SQL. Complete language documentation can be found here. There is also a very useful set of examples.
The query above, in short words, splits the timeline into 60-second periods and returns average values of humidity, temperature, pressure, and illumination for each period and each deviceld.
- Start your job
![Azure Stream Analytics: Writing the Query]()
7
8Step 8
Adding devices
- Register second device as described in Step 3.
- Upload and run code from Step 4 with modified connectionString value.
In short time the second curve appears in the report.
Dmitry Slepov
