Open LTPS Web Interface by simply entering its IP address in your browser, select the "Tibbits Layout" tab, and push the "Launch TPS Configurator..." button.
Setup Tibbits Layout as shown on the screenshot below and click File/Save
Note: TPS needs to be rebooted to take new Tibbits Layout into effect.
Assemble TPS according to the Tibbits Layout
Attention: it's strongly recommended to shut down TPS before placing/removing Tibbits.
Assembled device with the top cover removed
2
Step 2
First application
Node.JS, Git and Python 2.7 are installed on each LTPS by default, but NPM is not.
For installing, connect it to your device with SSH and do the following:
Microsoft Azure IoT Hub is a service that allows bi-directional communications between your devices and a solution back end. To complete this part of the tutorial you'll need:
TPS device(s) prepared as shown on the Step 0
An active Azure account
A PC with installed Node.js
Create an IoT Hub
Sign in to the Azure Portal
Choose New > Internet of Things > Azure IoT Hub
Configure your IoT Hub, then click "Create"
Wait a few minutes until your IoT Hub has been created then select All Resources > [name of your IoT hub] and click "Keys" icon.
In the Shared access policies blade select the "iothubowner" item and then copy the value of "Connection string" field.
