Fsociety_Keyboard_AltiumFiles.zipAltium Master Design files. Tested on AD16. Including the output job.x-zip-compressed - 3.57 MB - 08/21/2016 at 20:14 |
GERBER_fsociety(ready4prod).zipVersion0.10. Any PCB manufacturer should be able to handle it in a breeze. No difficult design requirement. I've done my homework, www.pcbway.com seems to be the cheapest and fastest. Give it a try. (Hold on. check my Log about this Gerber update before ordering)x-zip-compressed - 1019.28 kB - 08/21/2016 at 20:00 |
Fsociety_Keyboard_3D.pdfAdobe 3D design files, pan & zoom with this. NOTE: you have to download it first then open with your local Adobe reader. Hackaday's pdf plugin doesn't support this. I've tried.Adobe Portable Document Format - 28.66 MB - 08/21/2016 at 19:52 |
Fsociety_Keyboard_3DTop.PDFThe top view of non-compressed rendering of the Keyboard.Adobe Portable Document Format - 1000.54 kB - 08/21/2016 at 20:02 |
Fsociety_Keyboard_SCH.PDFThis is the complete schematic in pdf. Check the Original altium design files for more detail.Adobe Portable Document Format - 1.06 MB - 08/21/2016 at 19:55 |
Fsociety_Keyboard.DXFIn case you want to template the precise measurements or whatever. Use this .DXF file.AutoCAD DXF - 1.16 MB - 08/21/2016 at 20:18 |
Fsociety_Keyboard_3DBot.PDFThe bottom view of non-compressed rendering of the Keyboard.Adobe Portable Document Format - 836.49 kB - 08/21/2016 at 20:16 |
Fsociety_Keyboard.stepComplete export of the keyboard in Step files. Just for viewing, use the 3D pdf file above. The step export from Altium is too blocky. Not sure why.step - 37.29 MB - 08/21/2016 at 20:09 |
LICENSE.MDmd - 1.05 kB - 08/22/2016 at 00:03 |
Pamungkas Sumasta
