1Step 1
Do you want to build a robotic assistive arm like this? You can find all the instructions and step by step guids here: www.ourkidscandoanything.com
I really am impressed with your work.
But she will grown, how do you take that into account?
Apologies for the very late reply. To answer your question: The 3D printed braces are really easy to tweak as she grows, this was a core requirement of ours. In addition we are currently using the smallest actuator, as she grows and would require greater strength we could increase the size of the actuator and simply adjust the mounting pin location in the 3D file and print it out again.
Also we now have documented all the instructions for this project, you can find them here: www.ourkidscandoanything.com
