This was a project a few months in the making. I originally started it while I was still at SpaceX but really got to focus on it right before burning man 2013. I really wanted an 8 ft long carbon fiber staff with a ton of full bright white capable RGB LEDs on it. (I'm a big guy so I wanted something that felt big enough for me).
It went through two major revisions. The first one had a .75" diameter core round carbon tube from dragonplate and was scaffolded over this with laser cut acrylic spacers. The second revision had a 1" square carbon tube core from Pu-Feng, a custom routed carbon bridge piece/electronics enclosure in the center using v shaped clamping blocks to tie the two halves together. A polycarb cover was placed over the assembled staff to protect the LEDs.
If I had to do it again, I'd definately ditch the protective cover and try to move the LEDs inside the carbon (maybe a carbon truss structure as opposed to the tubes.) as it adds alot of weight and unnecessary complexity.
First Revision prototype
For the second prototype I scraped together some carbon tube from around the lab and got in on an order of 2811 addressable RGB LEDs via the local hackerspace Crashspace ( I think I originally ordered 10m or so, for ~ 300 dollars) I got some 7.4v 2.6 AH packs with built in protection boards from batteryspace and some step down regs from Pololu for bringing the voltage down to 5v.
Second staff:
Matt rigged up a teensy with a level translator to drive the LEDs ( I was originally using an arduino pro mini and adafruit's neopixel library, but the teensy was much better at high rate control of the LEDs). Then he added a couple of "modes" and a brightness/speed adjust paramter for the control knobs. I'll add a cool video and gif of the modes shortly
risknc
Kenneth Zaborny
CriptasticHacker
Using the Carbon fiber staff and Portable Rave for completing your creative project has increased its worth. One must visit https://www.australian-writings.net/ source to get help with essays writing assignment. I am so staggered to see the remarkable results your project is offering whenever I use it.
