36 Touch Sensor Matrix
“These aren't the duinos you're looking for. You can go about your business. Move along.”
!!! This is what happens when waiting too long for parts to be delivered on another project !!!
“36 touch sensor Teensy” is possible. I only did 20, pictured below because:
1. Lazy. The Teensy 3.1 has twelve touch sensor pins, nine through the hole already plugged into my breadboard, three solder pads on the bottom of its PCB.
2. I didn't have a space set up for soldering right now.
3. “Just because.” This was a fun experiment for me in Teensyduino for my Mouse Controller Project: http://hackaday.io/project/1125-Mouse-Controller-Project
Inspired by serious people:
http://www.pjrc.com/teensy/td_libs_CapacitiveSensor.html
http://www.pjrc.com/teensy/td_libs_Keypad.html
  • Visual spaghetti for circuit geeks, or...
    frankstripod • 06/07/2014 at 10:10 • 0 comments
    Its a 4 x 5 matrix of nine pin inputs to make 20 touch sensor “keys” (see table). Each key on the breadboard (noted in red) is made up of two wires so close together that it is impossible to unconsciously touch only one. It could be inspiration for a project that requires many other input and outputs, has limited space, and also needs a protected touch pad; like a CNC machine for hamsters.
     Touch Sensor Matrix:
    Pin# 1 2 3 4
    5 A B C D
    6 E F G H
    7 I J K L
    8 M N O P
    9 Q R S T
    Key Combo Key Combo
    A 1 5 T 4 9
    B 2 5 S 3 9
    C 3 5 R 2 9
    D 4 5 Q 1 9
    E 1 6 P 4 8
    F 2 6 O 3 8
    G 3 6 N 2 8
    H 4 6 M 1 8
    I 1 7 L 4 7
    J 2 7 K 3 7
    Board Layout
    Pinouts Matrix# Pinouts Matrix#
    0 1
    1 2
    . . 23 9
    . . 22 8
    . . 21 .
    . . 20 .
    . . 19 7
    . . 18 6
    . . 17 5
    . . 16 4
    . . 15 3
    Sorry the video is terrible; I'm still waiting to be rich so I can get better video equipment. I have been praying for my ship to come in, but just recently realized that I'm landlocked :(
    Sketchy code:
    I gave up on my original “easy to follow” code because it got frustrating. I started over out of anger to brute force it, and the main loop came out all at once as one line. If you squint hard and tilt your head to the right, (when spaced correctly in an editor) the shape of the main loop looks like the mountain skyline where I live and I wonder if this is a repressed Freudian sketch to some other problem.
    Voids warranties:
    /* Touch Sensor Matrix Test on Teensy 3.1
    Top 9 touch sensor pins, no bottom solder pads.
    4x5 matrix, 5 row 4 column = 20 touch key combinations.
    const int pins = 9, across = 4, down = 5;
    int touchPin[pins] = {0, 1, 15, 16, 17, 18, 19, 22, 23};
    int read1[pins], base[pins];
    char touchKeyValue[20] =
       {'A', 'B', 'C', 'D',
       'E', 'F', 'G', 'H',
       'I', 'J', 'K', 'L',
       'M', 'N', 'O', 'P',
       'Q', 'R', 'S', 'T'};
    boolean touched = false;
    int sensitivity = 140;
    int column, row, c;
    void setup() {
       Serial.begin(38400);
       for (int c=0; c<pins; c++) {
         base[c]=touchRead(touchPin[c]); // Baseline calibration
    void loop() {
      touched = false;
      for (c=0; c<pins; c++) {
         read1[c] = touchRead(touchPin[c]);
           if (read1[c]-base[c] < sensitivity) {
             touched = true;
      if (touched) {
        for (column = 0; column < across; column++) {
          if (read1[column] - base[column] > sensitivity) {
          delay(40);
          for (row = 0; row < down; row++) {
            if (read1[row+across] - base[row+across] > sensitivity) {
              Serial.print(touchKeyValue[row * across + column]);
              Serial.println(" Pressed");
              while (touched) {
                read1[column] = touchRead(touchPin[column]);
                read1[row+across] = touchRead(touchPin[row+across]);
                if (read1[column] - base[column] < sensitivity && read1[row+across] -          base[row+across] < sensitivity) {
                  Serial.print(touchKeyValue[row *...
View project log
Dimitar Tomov wrote 03/12/2015 at 20:28 • point
I was going to give you a SKULL only for the tagline under project's title, but then I wanted to give you 2 - 1 for the tagline and 1 for the project itself, but sorry - hackaday.io platform allows us to give only 1 :D but you have to know - this 1 now actually means 2 :D haha ... I'll look the project closely when i have the time, but I have to say move to pure ANSI C w/o that abstraction level of 10000+ ;-) every *uino is abstraction lvl over 9000 ;) GL !!!
