Flake Extruding Print Head SketchUp Model- V1 9-29-18.skp
Most current 3D model of flake extruding head I'm using on the MPCNC. So far, I know it works, in that it extrudes a consistent bead of plastic (currently PP, #5) in response to computer control of the stepper motor. Many improvements can (and will) be made to this design, but it's low cost, easily sourced parts, and good-enough performance warrant documentation. This model is MOSTLY to scale, but not in any technical way, so go by the stated measurements, rather than the model measurements, and make sure to check everything against what you can actually find at your local hardware store.
SSEYO Koan Play File -
4.74 MB -
09/29/2018 at 22:29
Download
