Do I hear solderless?
08/27/2018 at 13:55 • 0 commentsThat's right. This universal splice box can be used without a soldering station. Just twist the wires inside and add the hot meld glue:
- Print the splice box
- Peel off the insulation
- Insert the wires into the box
- secure the wires using cable ties
- Twist the wires together
- Fill in the box with hot melt glue
- Place the lid
- Wait for the glue to set and you're good to go
Added multiple files
05/26/2018 at 05:57 • 0 commentsI added today multiple files in the respective section. You can also download them from here:
https://cults3d.com/en/3d-model/tool/universal-cable-fix-splice-boxes
Added Cults location for the old design
04/18/2018 at 03:28 • 0 commentsThe Cults3D location for the old design can be found here:
Stay tuned for more updates and for the new cases which are making the object of this project.
Marius Taciuc
