It's running on the RPi now
09/22/2016 at 18:34 • 0 commentsSome tweaks were necessary before this started to work:
- update livestreamer
- install bc
- install imagemagick
I also tried to get rid of some error messages popping up when temporary files weren't there (yet), and this is the result:
#!/bin/bash # http://stackoverflow.com/questions/18279540/bash-shutdown-hook-or-kill-all-background-processes-when-main-process-is-kille threshold="0.1" fps="1/5" outfolder=/tmp/hdev-availability trap "jobs -p | xargs --no-run-if-empty kill; rm -r $outfolder" EXIT mkdir -p $outfolder livestreamer --player "ffmpeg -i" --player-args "{filename} -vf fps=$fps $outfolder/out%04d.png" https://www.ustream.tv/channel/17074538 worst & while true; do # find newest file and compare FILE=$(ls -t $outfolder/out*.png 2>/dev/null | head -n 1) if [ -f $FILE ]; then { output=$(compare -metric MSE -fuzz 20% $FILE references/novideo.png $outfolder/tmp.jpg 2>&1 1>&3-) ;} 3>&1 value=$(echo $output | cut -d "(" -f2 | cut -d ")" -f1) echo $value'>'$threshold | bc -l fi # remove old files # http://stackoverflow.com/questions/25785/delete-all-but-the-most-recent-x-files-in-bash (ls -t $outfolder/out*.png 2>/dev/null | head -n 2;ls $outfolder/out*.png 2>/dev/null ) | sort | uniq -u | xargs --no-run-if-empty rm # check if livestreamer is still running and restart if required # ... sleep 5 done
It's happily printing a chain of 1's and 0's, according to live video availability. Now I just need to- make it more reliable
- create a stream multiplexer that shows something else when live HDEV images are not available
- make the information available publicly
- reduce cpu load - ffmpeg uses a lot of resources and I'm not sure if that's necessary. Sometimes the cpu is fully loaded.
ffmpeg on the RPi
09/22/2016 at 05:17 • 0 commentsSo avconv is available as a package for raspbian, but I couldn't get it to work with my livestreamer command line out of the box (still testing on a ubuntu machine). I decided to compile ffmpeg on the RPi as per these instructions:
http://www.jeffreythompson.org/blog/2014/11/13/installing-ffmpeg-for-raspberry-pi/
Compiling x264 seemed to work just fine.
ffmpeg: cloning took quite some time. As the instructions mention that it can take a "REALLY long" time, I decided to time the make command just to have a number. I also used all four cores (make -j4). The result: 333 minutes, and the "recipe for ffmpeg_g failed". ffmpeg seems to work, though (executing it without arguments on the command line doesn't throw error messages), so I don't really care about that.
OK that's a start at least
09/20/2016 at 20:11 • 0 commentsSo I managed to write a bash script that
- launches livestreamer in the background, which streams to ffmpeg, which writes images captured from the stream to disk
- scans for those files and finds the newest one to compare with a reference image
- deletes old images
- kills the background livestreamer when it exits (this was hard-ish because of my low google-fu)
Here it is:
#!/bin/bash threshold="0.1" # http://stackoverflow.com/questions/18279540/bash-shutdown-hook-or-kill-all-background-processes-when-main-process-is-kille trap 'jobs -p | xargs --no-run-if-empty kill' EXIT livestreamer --player "ffmpeg -i" --player-args "{filename} -vf fps=0.1 out%04d.png" https://www.ustream.tv/channel/17074538 worst & while true; do # find newest file and compare FILE=$(ls -t out*.png | head -n 1) { output=$(compare -metric MSE -fuzz 20% $FILE references/novideo.png tmp.jpg 2>&1 1>&3-) ;} 3>&1 # extract and compare, output binary value indicating if HDEV stream is available or not value=$(echo $output | cut -d "(" -f2 | cut -d ")" -f1) echo $value'>'$threshold | bc -l # remove old files # http://stackoverflow.com/questions/25785/delete-all-but-the-most-recent-x-files-in-bash (ls -t out*.png | head -n 2;ls out*.png)|sort|uniq -u | xargs --no-run-if-empty rm # check if livestreamer is still running and restart if required # TBD ... sleep 5 done
Some things are still missing:- if the livestreamer process dies for some reason, I don't have a way to detect that and restart it (yet)
- temporary images and the compare result image should be written to RAM, because I want this to run on a raspberry pi. Writing this many images to the SD card will wear it out sooner than later.
- I'd like to publish this as a mqtt topic, but available to the public
