ISS HDEV image availability
The "High Definition Earth Viewing" experiment onboard the ISS runs a few cameras, but not always. Let's find out when video is available!
The "High Definition Earth Viewing" experiment onboard the ISS is quite simple: They run a few cameras and feed a live stream with images.
However, the downlink doesn't always work and so from time to time we're shown a static image stating that currently there's no live video available. During that time, I'd like to see something else, so I'm pointing some code at the live stream to compare it with the static image and determine if live video is available or not. Then, in a later stage, I can use this information to show something else instead.
If anyone is able and willing to help with this - I'm happy to take advice, even if it's about totally different approaches. No aspect of this (apart from the overall goal) is carved in stone.
About the HDEV experiment
Here's a link to the live stream and some info:
https://eol.jsc.nasa.gov/ESRS/HDEV/
It's supposed to include some tracking as well, but that doesn't show up in my browser. I like to open
http://www.isstracker.com/
along with the video to get an overall feeling for the station's orbit and where live video is available.
If you watch the live stream for a while you'll notice that it doesn't always show live images. Sometimes a still image is shown, stating that there's currently no live video available:
That's boring and a wall-mounted display, for example, could show something else during that time. That's the initial thought behind this project.
What I'm aiming for
Well my far goal is to have a small screen in my living room that shows either the HDEV stream - when an actual live image is available - or some other interesting stuff that I haven't specified yet.
Current state
I created an amazon web services account and use one of the free plans to run a linux system. The first step is to grab an image periodically, which is done by the following command:
streamlink -O http://ustream.tv/channel/iss-hdev-payload worst | ffmpeg -i - -r $fps -f image2 -update 1 out.jpg
  • streamlink receives the stream in low quality and passes it on to ffmpeg
  • ffmpeg converts to jpg at 5 fps (that variable is set in a script) and writes to out.jpg
The whole command is wrapped in an endless loop, so it automatically restarts when there was a problem with that caused streamlink or ffmpeg to abort/crash/whatever.
The second step is to analyze out.jpg whenever a new image has been grabbed and written. This circles around inotify. A python script uses pyinotify to get a notification whenever out.jpg was modified. The image is then read and compared against the "no live image available" image using structural similarity (I use this algorithm because I found a simple example here: https://www.pyimagesearch.com/2017/06/19/image-difference-with-opencv-and-python/ - seems to work ok!).
The result of this comparison is a bool value that is published via MQTT:
  • server: test.mosquitto.org
  • topic: iss-hdev-availability/available-bool
  • messge: a single character, either "0" or "1"
Making use of it
The first vaguely useful thing I did was to combine live image availability data with the ISS' current location, to draw and availability map. The corresponding project log is here:
https://hackaday.io/project/14729-iss-hdev-image-availability/log/151304-availability-map
ffmpeg_grabber.sh
Runs in the cloud, grabs frames periodically and writes the recent frame to out.jpg
x-shellscript - 350.00 bytes - 08/20/2018 at 20:36
Download
analyser_loop.sh
Runs analyse_03_threaded_mqtt.py (see other file) in the cloud
x-shellscript - 173.00 bytes - 08/20/2018 at 20:38
Download
Runs in the cloud (see analyser_loop.sh), compares out.jpg against novideo.jpg and publishes the result via MQTT
x-python - 1.88 kB - 08/20/2018 at 20:39
Download
Reference image
JPEG Image - 27.99 kB - 08/20/2018 at 20:35
Preview
iss_availability_position_24h.py
Subscribes to the MQTT topic and adds ISS position information to the availability value.
x-python - 1018.00 bytes - 08/20/2018 at 20:46
Download
View all 6 files
  • 1 × Linux system (I'm currently using an aws ec2 micro instance)
  • 1 × Internet connection
  • Availability map
    Christoph • 08/20/2018 at 09:07 • 0 comments
    What I got (red means: no live image available at that time/location):
    Apparently, the live image is more or less consistently not available between some 38° east and 95° east. That's just based on one day, though, starting from unix timestamp 1534627704 (August 18th 2018, 21:28 UTC)
    How I got there:
    Here's a script that, whenever HDEV live image availability data is received via MQTT, requests the current ISS position from a web service and combines that information. The result is written to stdout, from where I wrote to a file. I had this script running for 24 hours (it self-terminates after that period of time):
    # http://open-notify.org/Open-Notify-API/ISS-Location-Now/
    import urllib2
    import json
    import paho.mqtt.client as mqtt
    import time
    def on_connect(client, userdata, flags, rc):
      client.subscribe("iss-hdev-availability/available-bool")
    def on_message(client, userdata, message):
      try:
        available = message.payload
        req = urllib2.Request("http://api.open-notify.org/iss-now.json")
        response = urllib2.urlopen(req)
        obj = json.loads(response.read())
        timestamp = obj['timestamp']
        lat = obj['iss_position']['latitude']
        lon = obj['iss_position']['longitude']
        print("{},{},{},{}".format(timestamp,lat,lon,available))
      except URLError:
        pass
    client = mqtt.Client()
    client.on_connect = on_connect
    client.on_message = on_message
    client.connect("test.mosquitto.org", 1883)
    client.loop_start()
    start_time = time.time()
    duration = 24*3600
    while True:
      try:
        if time.time() > (start_time + duration):
          break
        time.sleep(1)
      except KeyboardInterrupt:
        break
    client.loop_stop()
    So now we have live image availability vs location, for a 24h period. The dataset is here:
    https://cdn.hackaday.io/files/14729630165536/hdev-availability.csv
    (it's also in the project files)
    That data can be drawn on a map. I found out that there's a map toolkit for matplotlib, and installed it. The rest is quite simple:
    import matplotlib as mpl
    mpl.use('Agg') # because the AWS EC2 machine doesn't have tkInter installed
    import matplotlib.pyplot as plt
    from mpl_toolkits.basemap import Basemap
    import numpy as np
    import csv
    # https://matplotlib.org/basemap/users/cyl.html
    m = Basemap(projection='cyl',llcrnrlat=-90,urcrnrlat=90,\
                llcrnrlon=-180,urcrnrlon=180,resolution='c')
    m.drawcoastlines()
    x = []
    y = []
    xn = []
    yn = []
    npoints = 0
    with open('hdev-availability.csv') as csvfile:
      csvreader = csv.reader(csvfile)
      for row in csvreader:
        npoints += 1
        lat = float(row[1])
        lon = float(row[2])
        available = int(row[3])
        if available:
          x.append(lon)
          y.append(lat)
        else:
          xn.append(lon)
          yn.append(lat)
    plt.title("HDEV live image availability (last {} h)".format(int(npoints*6/3600)))
    m.scatter(x,y,3,marker='o',color='black',latlon=True)
    m.scatter(xn,yn,3,marker='o',color='red',latlon=True)
    plt.savefig('hdev-availability-map.png')
    # plt.show()
    In the last line you see the save-image-to-file operation, and the result is the map shown at the top and again here:
  • CPU load observations
    Christoph • 08/18/2018 at 19:02 • 0 comments
    My image analysis is running on the amazon cloud and uses roughly 3 - 4 % CPU. One thing that sticks out, though, is that CPU load periodically increases slightly. The period is roughly the same as that of the ISS' orbit (about 90 minutes, 16 per 24 hours):
    I'll try to line this up with live image availability to see if it's actually related to the image analysis part.
    edit: turns out that image analysis consumes less CPU while the ISS is in the night half of it orbit, so the cameras show a black image.
  • Making use of the data
    Christoph • 08/17/2018 at 21:14 • 0 comments
    Now that the live image availability data is published as an MQTT topic that can be subscribed to, here's a script that combined this data with the ISS position:
    import urllib2
    import json
    import time
      try:
      except URLError:
        pass
    client = mqtt.Client("issclient")
    client.loop_start()
    while True:
      try:
        time.sleep(1)
        break
    client.loop_stop()
     I've got a modified version of this running which will will self-terminate after 24 hours, to draw an availability map.
  • Success!
    Christoph • 08/17/2018 at 08:40 • 0 comments
    I tried writing a python script that would use streamlink to connect to a stream, grab a frame every now and then, and analyse it. Whatever I tried, it would either be horribly slow or the stream would time out after just a few seconds.
    What works, though, is using ffmpeg as a player at a low-ish framerate and dump images to disk:
    Now I have a more or less recent frame every few seconds (I picked 0.2 fps for my application). I found that out.jpg from that command is usually ahead (think 10 to 20 seconds) of the image shown by the ustream web viewer.
    The command shown above runs in an endless loop in the cloud, so I don't have to keep a server running at home. The reason for the endless loop is that sometimes the stream times out or has other problems, and streamlink would then terminate.
    Now out.jpg can be analysed. Since it's now just a regular file, I had to check if it has been modified since the last image analysis. I tried pyinotify for this purpose and it seems to work well. Caveat: ffmpeg seems to write it three times per update, and each of these accesses generates a notification. A little deadtime between analyses fixed this. The analysis is a structural similarity measurement between the recently grabbed frame (out.jpg) and a snapshot of the "no stream available" image. Then the result is published to the mosquitto test broker. Here's the quick and dirty code:
    import pyinotify
    import time
    from skimage.measure import compare_ssim
    import imutils
    import cv2
    threshold = 0.9
    class EventHandler(pyinotify.ProcessEvent):
      template_img = cv2.cvtColor(cv2.imread("novideo.jpg"), cv2.COLOR_BGR2GRAY)
      template_width = template_img.shape[1]
      def __init__(self):
        self.start_time = time.time()
        self.last_event = 0
        self.deadtime = 1
        self.updated = False
        self.client = mqtt.Client("analyse_client")
        self.client.connect("test.mosquitto.org", 1883)
        self.client.loop_start()
      def analyse(self):
        self.updated = True
        now = time.time()
        if now > (self.last_event + self.deadtime):
          recent_img = cv2.cvtColor(cv2.imread("out.jpg"), cv2.COLOR_BGR2GRAY)
          recent_width = recent_img.shape[1]
          f = float(self.template_width)/float(recent_width)
          recent_img = cv2.resize(recent_img, (0,0), fx=f, fy=f)
          (score, diff) = compare_ssim(recent_img, self.template_img, full=True)
          t = now - self.start_time
          available = score < threshold
          print("modified @t = {:.3f} s; score = {:.3f}; available = {}".format(t, score, available))
          self.client.publish("iss-hdev-availability/available-bool", int(available))
        self.last_event = now
      def process_IN_CLOSE_WRITE(self, event):
        self.analyse()
    def main():
      wm = pyinotify.WatchManager()  # Watch Manager
      handler = EventHandler()
      notifier = pyinotify.ThreadedNotifier(wm, handler)
      notifier.start()
      wdd = wm.add_watch('out.jpg', pyinotify.IN_CLOSE_WRITE)
      last_event = handler.last_event
      while True:
        try:
          time.sleep(30)
          if handler.updated:
            handler.updated = False
          else:
            print("no updates, exiting")
            break
          print("keyboard interrupt, exiting")
          break
      #wm.rm_watch(wdd.values())
      notifier.stop()
    if __name__ == "__main__":
      main()
    This script is also running in an endless loop in the cloud since notifications won't come anymore after the grabbing command was restarted. I don't know why, but a loop does the job.
    So if you just want to know if an actual live image from the ISS HDEV experiment is available (without having to look at the actual video output), the topic "iss-hdev-availability/available-bool" on test.mosquitto.org can be subscribed to by anyone. Here's a screenshot from my phone:
    Of course it also works with a command line tool:
    mosquitto_sub -h test.mosquitto.org -t iss-hdev-availability/available-bool
  • streamlink
    Christoph • 08/14/2018 at 07:56 • 0 comments
    Streamlink is a fork of livestreamer and currently seems to be more stable when it comes to playing ustream streams. I had it running yesterday on an RPi 3 B+ and didn't have any connection loss (read error / stream timeout) for an hour until I just closed it.
    With livestreamer I wasn't able to get past a few seconds.
    So basically I'm at the start again, just being able to play the HDEV stream.
  • livestreamer seems to cause problems
    Christoph • 10/22/2016 at 21:07 • 0 comments
    Currently, using livestreamer on the Pi to get stream data results in this error:
    Traceback (most recent call last):
      File "01_parsepipeline.py", line 195, in <module>
        main()
      File "01_parsepipeline.py", line 172, in main
        streams = livestreamer.streams(url)
      File "/usr/local/lib/python2.7/dist-packages/livestreamer/session.py", line 355, in streams
        return plugin.streams(**params)
      File "/usr/local/lib/python2.7/dist-packages/livestreamer/plugin/plugin.py", line 233, in streams
        ostreams = list(ostreams)
      File "/usr/local/lib/python2.7/dist-packages/livestreamer/plugins/ustreamtv.py", line 550, in _get_live_streams
        streams = self._get_desktop_streams(channel_id)
      File "/usr/local/lib/python2.7/dist-packages/livestreamer/plugins/ustreamtv.py", line 513, in _get_desktop_streams
        provider_url = provider["url"]
    KeyError: 'url'
    Using the exact same code on my laptop works, kinda.
  • Works on laptop. Not on Pi.
    Christoph • 10/19/2016 at 20:22 • 4 comments
    This is the current script, which outputs the expected difference between the current stream image and a reference:
    #!/usr/bin/env python
    # GST_DEBUG=3,python:5,gnl*:5 python 01_parsepipeline.py http://www.ustream.tv/channel/17074538 worst novideo.png
    from __future__ import print_function
    import sys
    import gi
    from gi.repository import GObject as gobject, Gst as gst
    from livestreamer import Livestreamer, StreamError, PluginError, NoPluginError
    import cv2
    import numpy
    def exit(msg):
        print(msg, file=sys.stderr)
        sys.exit()
    class Player(object):
        def __init__(self):
            self.fd = None
            self.mainloop = gobject.MainLoop()
            # This creates a playbin pipeline and using the appsrc source
            # we can feed it our stream data
            self.pipeline = gst.parse_launch('uridecodebin uri=appsrc:// name=decoder \
                decoder. ! videorate ! video/x-raw,framerate=1/1 ! tee name=t \
                  t. ! queue ! videoconvert ! video/x-raw,format=RGB ! appsink name=appsink \
                decoder. ! queue ! audioconvert ! fakesink')
            if self.pipeline is None:
                exit("couldn't build pipeline")
            decoder = self.pipeline.get_by_name('decoder')
            if decoder is None:
                exit("couldn't get decoder")
            decoder.connect("source-setup", self.on_source_setup)
            vsink = self.pipeline.get_by_name('appsink')
            if vsink is None:
                exit("couldn't get sink")
            vsink.set_property("emit-signals", True)
            vsink.set_property("max-buffers", 1)
            vsink.connect("new-sample", self.on_new_sample)
            # Creates a bus and set callbacks to receive errors
            self.bus = self.pipeline.get_bus()
            self.bus.add_signal_watch()
            self.bus.connect("message::eos", self.on_eos)
            self.bus.connect("message::error", self.on_error)
        def on_new_sample(self, sink):
            sample = sink.emit("pull-sample")
            buf = sample.get_buffer()
            caps = sample.get_caps()
            height = caps.get_structure(0).get_value('height')
            width = caps.get_structure(0).get_value('width')
            (result, mapinfo) = buf.map(gst.MapFlags.READ)
            if result == True:
                arr = numpy.ndarray(
                    (height,
                     width,
                    3),
                    buffer=buf.extract_dup(0, buf.get_size()),
                    dtype=numpy.uint8)
                resized_refimage = cv2.resize(refArray, (width, height))
                diff = cv2.norm(arr, resized_refimage, cv2.NORM_L2)
            buf.unmap(mapinfo)
            s = "diff = " + str(diff)
            print(s)
            return gst.FlowReturn.OK
        def exit(self, msg):
            self.stop()
            exit(msg)
        def stop(self):
            # Stop playback and exit mainloop
            self.pipeline.set_state(gst.State.NULL)
            self.mainloop.quit()
            # Close the stream
            if self.fd:
                self.fd.close()
        def play(self, stream):
            # Attempt to open the stream
            try:
                self.fd = stream.open()
            except StreamError as err:
                self.exit("Failed to open stream: {0}".format(err))
            # Start playback
            self.pipeline.set_state(gst.State.PLAYING)
            self.mainloop.run()
        def on_source_setup(self, element, source):
            # When this callback is called the appsrc expects
            # us to feed it more data
            print("source setup")
            source.connect("need-data", self.on_source_need_data)
            print("done")
        def on_pad_added(self, element, pad):
            string = pad.query_caps(None).to_string()
            print(string)
            if string.startswith('video/'):
            #type = pad.get_caps()[0].get_name()
            #print(type)
            #if type.startswith("video"):
              pad.link(self.vconverter.get_static_pad("sink"))
        def on_source_need_data(self, source, length):
            # Attempt to read data from the stream
            try:
                data = self.fd.read(length)
            except IOError as err:
                self.exit("Failed to read data from stream: {0}".format(err))
            # If data is empty it's the end of stream
            if not data:
                source.emit("end-of-stream")
                return
            # Convert the Python bytes into a GStreamer Buffer
            # and then push it to the appsrc
            buf = gst.Buffer.new_wrapped(data)
            source.emit("push-buffer", buf)
            #print("sent " + str(length) + " bytes")
        def on_eos(self, bus, msg):
            # Stop playback on end of stream
            self.stop()
        def on_error(self, bus, msg):
            # Print error message and exit on error
            error = msg.parse_error()[1]
            self.exit(error)
    def main():
        if len(sys.argv) < 4:
            exit("Usage: {0} <url> <quality> <reference png image path>".format(sys.argv[...
  • Python script
    Christoph • 10/11/2016 at 19:29 • 0 comments
    So here's the first working python script, ignoring all good practices like checking for return values or doing things in the right place. It also doesn't output zero and ones, but a float that is the L2 norm between the current frame and the reference frame. But in a way it does the job:
    import sys
    import gi
    from streamlink import Streamlink, StreamError, PluginError, NoPluginError
    import cv2
    import numpy
    def exit(msg):
        sys.exit()
    class StreamlinkPlayer(object):
        def __init__(self):
            self.fd = None
            self.pipeline = gst.Pipeline.new("player")
            source = gst.ElementFactory.make("uridecodebin", "decodebin")
            source.set_property("uri", "appsrc://")
            self.pipeline.add(source)
            self.vconverter = gst.ElementFactory.make("videoconvert", "vconverter")
            vsink = gst.ElementFactory.make("appsink", "videosink")
            caps = gst.caps_from_string("video/x-raw, format=(string){RGB}")
            vsink.set_property("caps", caps)
            filter = gst.ElementFactory.make("videorate", "fpsfilter")
            filter.set_property("max-rate", 1)
            self.pipeline.add(self.vconverter)
            self.pipeline.add(filter)
            self.pipeline.add(vsink)
            self.vconverter.link(filter)
            filter.link(vsink)
            # self.vsink = vsink
            source.connect("source-setup", self.on_source_setup)
            source.connect("pad-added", self.on_pad_added)
            self.stop()
            exit(msg)
        def stop(self):
            # Close the stream
            if self.fd:
                self.fd.close()
            try:
            # Start playback
            self.mainloop.run()
            print("done")
        def on_new_sample(self, appsink):
            sample = appsink.emit("pull-sample")
            if result == True:
                    (height,
                     width,
                    3),
                    dtype=numpy.uint8)
                sum = int(0)
                print("diff = " + str(diff))
            buf.unmap(mapinfo)
            print(string)
            try:
            if not data:
                return
            self.stop()
     error...
  • Doing it in python
    Christoph • 10/10/2016 at 09:02 • 0 comments
    Starting with the livestreamer player example I was able to move away from a very hacky bash script to something in python. This involved reading lots of examples for gstreamer and figuring out if they were for gstreamer 0.1 or 1.0, reading the corresponding documentation and simply giving it a try.
    The overall approach is quite simple. The example simply shows the stream using gstreamer's appbin. appbin is replaced by a custom pipeline which allows me to do two things:
    • limit to one frame per second
    • analyze the raw frame in the python script instead of displaying it
    That custom gstreamer pipeline currently looks like this:
    uridecodebin -> videorate (limit to 1 fps) -> appsink
    the uridecodebin element is fed with data from the live stream, and the appsink provides a raw buffer. Now what's left to be done is to actually compare the current frame with the reference frame, and to publish the result in some way.
  • Sample output
    Christoph • 09/22/2016 at 20:15 • 0 comments
    The script has been running for about 90 minutes now, and shows no signs of giving up yet. Here's the script's output with stream shown in the background, while no live image is available:
    The output shows five zeros in a row, meaning that, at 0.2 fps, the still image has already been there for about 25 seconds. After a while the signal is back and we get this:
    The script spits out 1's again after about 13 x 5 = 65 seconds. Great! In the meantime, the ISS passed by somewhere over argentina or the south atlantic.
View all 13 project logs
