At the moment I have working
- 2x DHT22 sensors
- Internal circulation fan output
- External Fan output
- 600w light
- 2x soil sensors - Working, Can be set from front panel.
- 2 x water pump outputs (controlled by soil sensors). Pumps will start watering if the soil moisture level raises above the level set it the menu and will run for a set time. This is checked once every hour. This is because i have the soil sensors deep into the soil and wanted to allow enough time to soak up.
- water pumps can be controlled via a timer instead of sensors. (Had to put this on because as sensors degrade they start giving stupid readings so needed a way to turn sensors of to avoid overwatering. (Yes I learnt the hard way, full water resovour dumped inside grow room. Lol
- LCD - Working, Displays current temps/ Humid, Time,
- Heater - Working, When temps drop below a set level heater will turn on until temp raises 5 degrees celsius.
- i2c realtime clock
- Menu system displays Timer menu, Pumps menu, Temps menu
- Bluetooth serial connection
- Fona GSM module (Not implemented yet) :(
dannyritchie
Nelson Butterworth
Saabman
Audrey Robinel
Among the products mentioned on the list, which one is the best?
https://householdneed.com/best-smoothie-blenders/
