Hackaday.io Hackaday.io
Sign up Log in
Renter's Security
Security system for a rental apartment.
alden-hootAlden Hoot
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 4
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
307
0
1
2
Team (1)
  • alden-hootAlden Hoot
Join this project's team
hardware
ongoing project
security home automation raspberry pi Intrusion Detection
This project was created on 09/13/2016 and last updated 9 years ago.
Description
Chance to learn the basics of RaspPi development and maybe make a friend's apartment a little safer along the way.
Files
AMP2009_NAIS datasheet.pdf
Data Sheet for IR Motion Detector
Adobe Portable Document Format - 622.94 kB - 09/13/2016 at 16:15
Preview
Components
  • 1 × Raspberry Pi 2 b https://www.raspberrypi.org/products/raspberry-pi-2-model-b/
  • 1 × Pi NoIR Infrared Camera Module v2 https://www.raspberrypi.org/products/pi-noir-camera-v2/
  • 1 × Samsung EVO Micro SDHC 16GB card
  • 1 × Ethernet cable
Project Logs
Collapse
  • Finally got Motion working with Pi Cam & Jessie
    Alden Hoot • 03/08/2017 at 15:56 • 0 comments
    After much struggling with my own ineptitude, I finally found some solid documentation on how to update the libraries needed to run dozencrows modified version of Motion with integrated support for the Raspberry Pi Camera board with the latest version of Raspbian (codenamed Jessie)! Huge shout outs to @lowflyer for their forum post and Robin Newman who's blog post got me started down this road after my previous efforts at making the Pi Cam report itself as a standard webcam device hit a dead-end.
    It appears that one is still unable to capture at anything like the full resolution of the camera, but I have at least been able to capture watermarked video of movement at 640x480 or 640x576, which will probably be good enough for my purposes, at least for the moment.
  • More inspiration
    Alden Hoot • 09/16/2016 at 04:45 • 0 comments
    by ScreechyNutz's team.
    Link to Python Script: http://www.raspberrypi.org/learning/p...
    Dropbox Core API: https://www.dropbox.com/developers/core
    Mail setup on the Raspberry Pi: http://iqjar.com/jar/sending-emails-f...
    Script: http://pastebin.com/mUh6LzMZ
    Also
    by rdagger68
  • And So It Begins
    Alden Hoot • 09/13/2016 at 16:13 • 0 comments
    This project has been brewing for a while, and I keep coming up with new sources of inspiration like this: https://www.youtube.com/watch?v=pvHIV0bNRe4
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
A Pi, in a Bauble!!
Project Owner Contributor
Ho Ho Ho Pi
mooseprmoosepr
Ambient lighting using a Raspberry Pi and recycled monitors
Raspberry Pi Video Wall
conradcnconradcn
So I just got my hands on the new Raspberry Pi4 2G Model B and I was wondering if it is powerful enough to run win7 (32 or 64 bit)?
Win7 on Raspberry Pi 4 ?
dirac1deltaDirac1Delta
was given a Raspberry Pi as a gift and have been on a mission to learn everything it can do.
Raspberry PI
hatterofthewasteHatterofthewaste
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Renter's Security", please tell us the reason.
Send message
Remove Member
