SAM - Solar Automation Machine.
Sun Tracking, Charging, Cooling , Monitoring, Relay control. for my small solar panel installation.
Solar Automation for a small solar install in my backyard.
I'd like to monitor my solar panel installation while maximizing the return that I get from them.
This will mean I will need to track the sun, have an efficient charging method and possibly cool my panels in the summer months. It would also be nice if it could control some higher power 12v garden lights or other accessories in the yard.
All code that can be will be open sourced and uploaded to github as it becomes polished.
Sam is to be a smart solar charge monitor and controller with extras.
SAM will:
-monitor the voltage and current on my solar panels
-monitor the voltage and current on my batteries
-monitor the temperature of the panels and system
-monitor the light levels of the sun
-move the panels to stay in the sun
-charge the battery with an arduino mppt charger if time permits.
-turn on devices like garden lights, water pumps, lawn ornaments, or even model rockets.
-Store all the sensor data to sd card
-Upload data sets to solar.pxn.ca via wifi.
-Display the current status on an lcd
Where am I at today:
Much of the rough hardware is now completed, I need to put it all together and finish work on the software.
SAM consists of:
- Arduino Mega
- cc3000 wifi shield
- 12V 8x Relay board
- Sunforce Charge Controller
- Voltage & Current sensors
- Temp Sensors
- Alarm
- Lcd Display
- Solar panels and batteries
- Linear actuator
- Sun tracker module
What code can be open sourced will be open sourced as it becomes polished.
The current online instance at http://solar.pxn.ca is just for testing/proof of concept, (though is mostly functional)
Arduino libraries will be used  for wifi c30000 , lcd display and possible more.
A database abstraction library might be used on the web side to ease database interaction.
More will be known about the software license compatibility as it's developed.
  • 2 × ACS712 20A Current Sensor Module Now using these
  • 1 × Anderson Power Poles used for connecting extras
  • 1 × Large type andersons? Found at the garbage. used for connecting the larger panel wiring
  • 1 × Junction Box to store the same components
  • 1 × Radio shack project box to make a sun tracker box
View all 17 components
  • Yay Progress.
    Emerica01/03/2016 at 07:35 0 comments
    Hackaday Prize Done Twice over.
    Ditching CC3000. Slimming down to basics for hamshack battery charging, will build up as needed.
    Still want temp and light sensing/logging but not a priority.
    Arduino mega
    DFRobot Mega Sensor Shield 2.4
    DfRobot Voltage dividers x2
    DX 20A Current Sensors
    Ebay 5A buck converter, with charging protection
    Switching Psu
    LCD
    Debug/NormalSleep Switch
    Might use RTC/SD Card for logging
    Temp, Light, Relay etc all left aside for the moment.
    2 modes selected by switch,
    Mode 1, delay 1000ms, always on quick update for debugging during setup.
    Mode 2. check sensors, delay 8000ms, kill backlight, then put arduino to sleep for 52s
  • Spring is here.
    Emerica04/08/2015 at 21:23 0 comments
    I really should have been working on this over the winter, but Ham radio took over, between work, snow activities and HR, I was kinda swamped.
    While doing some spring cleaning I found a voltage regulator I ordered last year in hopes of making the arduino run more efficient from the batteries. The vreg on the arduino itself is not very happy bringing ~13V down to 5V without making tons of heat.
    This adjustable regulator DE-SWADJ seems to be working rather well, stays cool and so does the arduino.
    I've set it about 6.3V, anything less and the LCD starts to become hard to read, with the onboard regulator.
    I've now dropped it down to 5.5v and used the vin, any lower and agin the lcd becomes faded.
    Planning to order some voltage sensors to replace my dividers, and maybe a sensor shield to clean up a bunch of the wiring.
    I've also found a bunch of proper stand-offs that I can set into the plastic sheet and mount everything better.
    More progress as time allows.
  • Didn't make the cut... Oh well , Space is a vacuum and vacuums suck.
    Emerica08/25/2014 at 21:18 0 comments
    Well, I've had SAM on the panels and connected to the web, off an on for the past couple days. Saturday I ran into reset problems. It seemed when the panel/battery voltage was brought over 13.5V the arduino and shield would reboot.
    I got a regulator kit from our electronics shop lm317 I think? and it now sits in between the battery voltage and the arduino system, I have it set for 7V, but I might bump that to 9V ?
    I'm having some problems now with the temperature sensors, so I bought new ones some replace the ones I mangled a bit. Temp sensing on the panels is broken at the moment, system temp is ok.
    The charge controller is showing it's worth now.  What seems to be happening is when the charge controller gets the batteries up to the 14.4V it shorts out the panels.
    I loose sensing on the voltage and amperage. Sun still shines bright giving me nothing.
  • Box progress, almost there.
    Emerica08/18/2014 at 14:31 0 comments
    SAM is coming along, much of the junction box is now mostly complete and I finally put the top cover on properly.
    There is still work to do inside, mostly sealing the box and replacing the sma cable that I broke, which connects my external ant. You might see a laptop ant in the box right now, with it's long skinny white wire looped around inside.
    I tried to keep the number of wires floating around inside to a minimum and am happier with less of a rats nest inside. Much of this was done by routing power and ground around on the backsides of the relay and power boards.
    The power board  Contains 2x 20A current sensors and 2x voltage dividers.
    I left headers to the solar panel and the battery connections there and also bring the 5v from the arduino to a set of headers on this board.
    I have a bunch of cat6 and had the keystone jacks laying around from another project, seeing as I used cat6 for the sun tracker and temp sensor wiring, it seemed fitting to use them and terminate the "module" ends with rj45 jacks. Not being any kind of electrical engineer, I'm not sure this is the right way to wire it all up, but values don't differ much, if at all, from the values of the sensors I had directly plugged into the arduino. I  had it all on hand as well, so $ saved.
    The temp sensors on the solar panels previously hot glued on, I thought it would work. I thought wrong. After the first day in 30C temps, the panels hit 55C and the hot glue fell right off on both panels.
    I need to think about a better way to hold these on through summer and winter.  For now I've duct taped everything to the back, I might have the same problem with it's adhesive. Time will tell and I can research alternatives in that time.
    The small strip to hold it while I got the rest of the tape down.
    Basic todo list :
    - build a bracket to mount the sun tracker to the top of the dish.
    - mount the actuator to the dish so that it's able to rotate it without being in a stressed position
    - Drill a usb and sd retrieval port. Make a cover with polymorph maybe?
    - Get a new sma cable
    - Seal the box
    - Mount everything
    - Program.
  • Sun Tracker Module
    Emerica08/17/2014 at 05:09 0 comments
    Testing the functionality of the sun tracker module
    The suntracker is made from :
    - a radio shack/ thesource project box.
    - protoboard
    - 3x photo resistors
    - 3 resistors
    - some cat cable,
    - rj-45 jack
    - heat shrink
    - rubber tubing
    - hotglue
    The idea with this sensor is to try to always keep the middle sensor higher than the outside two.  If you can do this , the sensor should stay pointed towards the brightest source of light in it's range, hopefully the sun.
    The two photo resitors  on the outside are angled away from the center to be less sensitive to direct sunlight and to be more sensitive to side angles, like a sunrise or set.
    After trying a bunch of different photo resistors in the breadboard, I found that the sun was overpowering them and it was going to be kinda tough to have enough variance between sensors. I tried playing with different resistors, the solar garden lights with ldr's sometimes have a 15k omh resistor connected, so I tried 3 of those, or so I thought. 2 sensors maxed out in the sun and one was much lower, a reasonable reading I could work with.
    Wondering what was going on I took a closer look at the board and noticed a red stripe instead of an orange one. 1.5K seems to work. So I changed them all to 1.5K. I'm sure this will vary with different photo-resistors so you will have to experiment, or dig into datasheets and do a bunch of math.
    Hot glue holds in the tubes and diffuses the light, probably change over to silicone as the hot glue fell off the panels in the heat already.
    I used cat6 to wire it all, rj45 for a connection to the box, I used heat shrink to help seal it up. The inlet and edges on the project box still needs to be sealed with some silicone.
  • Actuator Control, New Battery, Desulfator
    Emerica08/17/2014 at 05:08 0 comments
    I got the actuator working, with the Arduino, not having a pot wire from the actuator, I wont have the position the actuator is at,  There are limit switches so I will still be able to use it, just not as clean as I would like.
    Found another deep cycle at the garbage running on a new pulser,seems like it's going to hold a decent charge.
    I have since added this battery to the array, there are now 12 batteries in the array and the pulsetech pulser has been connected on all three since the video.
  • More updates to the external enclosure.
    Emerica08/17/2014 at 05:07 0 comments
    Still more to go but here is another update on the progress of the junction box.
  • Relays are too much fun
    Emerica08/17/2014 at 05:06 0 comments
    I got the relay board working, very happy.
  • Progress on the Outdoor enclosure.
    Emerica08/17/2014 at 05:05 0 comments
    Toying around with getting everything to fit in the box, found some wire from an also satellite receiver  to connect the relay board. Just a bunch of tired rambling in this one, but it's coming together.
  • Moving off the breadboard to an enclosure.
    Emerica08/17/2014 at 05:04 0 comments
    I need a nice box to hold everthing, it needs to seal well, but it would also be nice to be able to see inside.
View all 15 project logs
Rich text editor
sophia lily wrote 06/01/2024 at 10:08 point
It also gives me the creeps. I know I turned off the cooker, but the thought of losing everything makes me question my judgment. I may feel calmer just by staring at my smartphone in this way. Visit our website at https://www.customlanyards.ae/ to see the lanyards that I am designing
worios wrote 04/30/2023 at 17:28 point
The SAM (Solar Automation Machine) is an innovative solution designed to automate and streamline solar panel installation processes. Developed with advanced technology and precision engineering, SAM revolutionizes the efficiency and accuracy of solar panel installations.
Moreover, SAM incorporates advanced connectivity and control systems, allowing for seamless integration with other components of a solar power system. It can be integrated with monitoring and management systems to provide real-time data on energy production and system performance.
With Worios, a state-of-the-art technology designed to enhance performance and efficiency, SAM utilizes advanced energy management and optimization techniques. This ensures that the solar power system operates at its highest efficiency levels, maximizing energy production and minimizing losses<a href="https://worios.com/">Worios</a>
Paul Reith wrote 07/11/2014 at 22:10 point
Great idea for an affordable active cooling solution.
Manufacturers like SolarWorld publish efficiency charts, and efficiency drops as it warms. I.e. their sw 270 panel:
THERMAL CHARACTERISTICS
NOCT 46 °C
TC Isc 0.04 %/°C
TC Voc -0.30 %/°C
TC Pmpp -0.45 %/°C
Operating temperature -40°C to 85°C
For cooling, instead of putting the reservoir in the ground, you could just run a line out, which would be easy to install, and increase your surface area exposed to the heat sink (ground). I'd send it from your reservoir out through the loop, then directly to the panel.
This is essentially how a groundwater heat pump works. If that concept isn't easy for you to translate, look at a "jockey box" for beer. same concept.
Paul
Emerica wrote 07/11/2014 at 22:28 point
Hey thanks, very appreciated, I'll be looking into that as I get some free time.
We built a shed right next to my solar setup which is right near the rain gutters.
I may change to a less active system and use gravity and a grey rain water storage higher than the panels in the shed., sending excess to the garden. THen I only have to control a couple valves and watch a flood meter instead of running a pump. All in the air for now, getting tracking and some other things sorted out first.
Emerica wrote 07/11/2014 at 22:56 point
So after watching the MAKE, jockey box cooler video, you essentially mean do a closed loop coil in the ground?
I wasn't really keen on sinking the back of the panels yet, I've thought about a bladder, and also using heatings and peltiers, but the return I think would be negligible.
I was just going to wash them essentially, so I either need to recycle the water at the bottom or find a relatively free source of water to keep in the system. I'm not quite sure at this point, how I would return the water to a semi closed loop res, besides running a catch basin to the coil to the pump. Testing that pump and finding a supplier of that or very similar pump/price so others can duplicate and I can get specs would be nice.
Mike Szczys wrote 06/22/2014 at 13:42 point
I don't know the reason for adding water cooling. Are they less productive as the temperature rises?
Emerica wrote 06/23/2014 at 05:45 point
Very much so.
Emerica wrote 06/23/2014 at 05:46 point
Though, I don't have any hard numbers on my setup. Soon :)
Emerica wrote 07/01/2014 at 20:36 point
Did a few half assed tests today. I have a 60W panel, a 15W panel and a 1W panel. Today it's beautiful. 25-30C Sunny. When I first measure the temp on the panels they were ~50C so I cooled them and just watched the voltage, with little to no change. Let them warm up again to about 40C and hooked up another meter to check the amps.
At 40C I was about 13.5V at 3.8A, as soon as I started to cool the panels, the amps started to rise. I misted the panels for now just to test and when the panels reached about 30C I had 4.05 , sometimes 4.09A.
So my math tells me I'm getting about 3W back by keeping the panels 10C cooler.
Emerica wrote 07/01/2014 at 20:43 point
This should be fairly easy to calculate by the temp coefficient rated on the panel but real world is what matters.
