My first idea was to use a Nymi band to handle cryptography and comunication but it will take a while to get mine. I'm trying to get in the Developer Program...
In the meantime I will use my Pebble (that AFAIK only connect to a phone).
A bluetooth 4.0 device to open and close the doors, trunk and start the car.
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs (you got this)
- A system design document (I couldn't find it)
- Links to code repositories, and remember to mention any licenses or permissions needed for your project.
There is a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
