Packaging the sensor
08/27/2018 at 13:22 • 0 commentsI modified an adult sized pacifier to hold the tracking sensor. The sensor is configured to use just 3.3V, GND, SDA, and SCLK signals.
Reverse Engineering
08/27/2018 at 13:14 • 0 commentsDisassembled blackberry module:
The desoldered tracking chip:
Early attempt at working out the pinout:
Initial development
08/27/2018 at 13:07 • 0 commentsInitially I was working to reverse engineer the interface for the optical trackpad/joystick/navigation buttons used on a number of blackberry phones.
These modules are essentially tiny cameras with built in logic to determine the frame-by-frame differences of the surface being tracked, usually a fingertip, but a tongue should work as well.
I purchased modules from two different phone models, but they turned out to use completely different internal tracking modules.
