1Step 1
- order the board from OSH Park here: https://www.oshpark.com/shared_projects/SkULVRHA , the price for three 4 layer pcbs is $12.50
- follow the bom when ordering and hand stuffing components, solder on the oled display but do not tape it down
- burn in the bootloader using the Segger J-link, Digi-Key #899-1008-ND, 899-1012-ND
- follow the bootloader instructions: https://learn.adafruit.com/proper-step-debugging-atsamd21-arduino-zero-m0/restoring-bootloader
- pogo pins are needed for the bootloader: MILL_MAX 855-22-010-10-001101
- connect the board to the Arduino IDE, pick Adafruit Feather M0 as the board, choose the right com port and load in the sketch and if the display works tape it down
