We are developing a hardware platform that aims to simplify the process of embedded hardware design. The solution should capture user requirements and generate schematic and layout designs as intelligently as possible. The solution can help save a lot of time by helping you search for components, selecting micro-controller pins to connect, Different component configurations, clock selection, power supply design, Intelligent component placement in the smallest board area, layer selection and layout generation. The current Library contains 950+ controllers with complete family of STM microcontrollers, esp32 module, Atmel ATsame70, NXO imx6, and 7 series and several more. The solution creates designs in typical 10 minute time. The designs generated can be customized as per your requirements. For more details visit https://circuit-tree.com
Details
Components
1×
Complete Library
Most of the type of embedded components are found on circuit tree
Circuit tree library now has more than 900 processor and controllers. The library consists of complete stm series of controllers and commonly used processors from NXP imx6 , Texas intrument, NVDIA. Library also contains wide range of peripherals which are used in embedded boards.
Real time cost of the bill of material along with the links to order components from octopart are available in excel sheet.
Under export Schematic Designs are getting generated for eagle and altium pcb tools.
