Hackaday.io Hackaday.io
Sign up Log in
Hydraulic Exo-Skeletal Arm (Hesa)
An arm that uses the elbow as a fulcrum. Doing this allows for extreme weight to be lifted, like a car jack.
gavin-martinGavin Martin
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
4 comments
51 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
  • Official Hackaday Prize Entry
View Gallery
1.5k
4
51
14
Team (1)
  • gavin-martinGavin Martin
Join this project's team
  • HESA Video
hackaday electronics robotic hydraulics TheHackadayPrize exoskeleton hesa strength
Related lists
2014 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2014 Hackaday Prize
This project is submitted for
This project was created on 06/22/2014 and last updated 12 years ago.
Description
The hand has a free moving glove that is supported by metal. The metal parts of the glove attach to the forearm plate through hinges. The forearm plate is molded in the shape of a forearm, and is made of metal as well. The forearm plate is then attached to the shaft of the hydraulic cylinder. The hydraulic cylinder is attached to the upper arm plate. The hydraulic cylinder's shaft is naturally extended. The shaft decompresses from an electrical signal on the wearer's bicep detected from the EMG(electromyogram).
Details
Log In/Sign up to comment
Sign up with Github
OR
jlbrian7 wrote 07/31/2014 at 23:55 • point
if you havn't seen it already you may want to look at schilling robotics (now fmc), or just google "ROV manipulator". you can control a rate arm spatially with pwm to some degree. for the scale you are at it may work for a prototype.
J Groff wrote 07/22/2014 at 18:43 • point
When I was a little kid watching the Six Million Dollar Man I always wondered why his normal arm moved as fast as his super bionic arm when he ran instead of flapping like a noodle at 60 mph and why his super bionic arm didnt just rip out of his normal human shoulder when he lifted a car. Perhaps this project will answer some of those questions.
Adam Fabio wrote 07/01/2014 at 04:53 • point
I love anything that makes my life easier. If this exoskeleton will make lifting my car easier, I'm all for it! Thanks for entering the Hackaday Prize! Please try to upload some more information on your project - How will it be powered? How do you ensure the users safety (The arm is great, but how do you make sure the wearer won't overload their un-aided shoulder joint?)
Jixijenga wrote 07/06/2014 at 00:00 • point
In regards to that, I have a suggestion:
Perhaps add secondary tactile sensors that will interrupt the flow to the actuator if they sense an increasing pressure. An example being extending the arm, a sensor that would detect the edge of the forearm being pressed against it would override the EMG sensor. Parameters would have to limit when and how the controller accepts input from these sensors. I would imagine they would have to sense an invalid motion in more than one area, and the motion would have to be normally valid but outside of the safe range of operation.
I suppose if the arm was used in an industrial capacity this could be taken a step further. Instead of merely saying, "hey, stop moving!" the sensors could also trigger the opposite actuator and say, "hey, reverse motion!" if the arm was forced beyond into an invalid position. There would have to be a limited range that would trigger this effect, immediately prior to the invalid range.
Also, as for the shoulder joint issue, the arm would have to be supported by a some type of harness, probably one that mimics a heavy hiking pack. (one with a back frame) Something to evenly distribute the load on the shoulders, hips, and against the back, especially in an industrial model. Assuming this arm is used for medical assistance, perhaps some limited support against the rib cage or using other parts of the torso could also be included.
This is a 1/2.5 scale VW engine and transaxle with all internal parts.
Project Owner Contributor
VW Engine and Transaxle
wglasfordwglasford
3d printed transmission for nema 17 stepper using 6mm GT2 belt+pulley and bowden cable
3d printed stepper actuator
istvn-ntaiIstván Nótai
Exoskeleton arm made of aluminum and steel cable
Exoskeleton
roger-cobraRoger Cobra
A 6 degrees of freedom robotic prosthetic arm
Robotic Prosthetic Arm
jordan-rjaudJordan Réjaud
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Hydraulic Exo-Skeletal Arm (Hesa)", please tell us the reason.
Send message
Remove Member
