Whats New?
- Coded a second ROM page.
- The monitor code spans both ROM pages.
- The monitor is both hardware and emulator friendly (i.e. delay rountine added).
- An "Address to Page" decoder routine has been added.
- The Interpreter has been coded but not currently in use.
- The counting demo with delay is machine code.
Version 4
- The Emulater assumes read/write of registers (assumes PCBs will be reworded to suit).
- A bit of a re-organisation the Monitor code.
- Update Reset code.
- Add all the ROM and RAM pages.
- Add code to the Monitor to change RAM pages (uses PAGE PTR), until PCB boards have been updated for register read/write.
- Coded the Interpreter and some support subroutines (ROM PAGE 2).
- Add PP (Page Pointer) to keep track of the Interpreted Page.
- The Interpreter still to be tested.
The Emulater itself is now pretty complete.
AlanX
