UK40OB - Ultimate K40 Laser Cuter upgrade
Get a larger cut area on the stock K40 laser cutter
The K40 laser cutter is the most famous machine of its type at the moment. The main reason is the price. If you try to assemble tis machine from parts, it surely be much more than the current 300 ish USD you find for a new one on ebay.
So what does this machine get you? A Co2 laser cutter with a cut / engrave area measuring 200mm X 300mm ( 12"x8"). Now after a couple of month using it myself.... " I want moreeeee"
I decide to find use some Openbuilds profile i had from a large 3D printer i made to build a new gantry inside the current case, and thus the UK40OB was born
UK40OB K40 Lasr Cutter Final Parts.skp
Source file for the parts used on the UK40OB in Scketchup
SSEYO Koan Play File - 246.86 kB - 10/07/2016 at 03:45
Download
UK40OB final parts.svg
svg for the parts used on the UK40OB
svg+xml - 448.62 kB - 10/07/2016 at 03:45
Preview
View project log
  • 1
    Step 1
    Cut the parts to be used in the assembly. Else how are you going to assemble the new parts? :)
  • 2
    Step 2
    Remove all the internal of the original K40 laser cutter
  • 3
    Step 3
    Measure and make the holes on each side of the case
View all 8 instructions
sammie928s wrote 07/15/2019 at 03:40 point
Thanks mate nice hack!
asmoviv wrote 06/13/2017 at 23:50 point
Hi, I really like the simplicity of your modification.
I started to dismantle mine and would like to know the lengh of the 20*40 rail you ordered.
Thanks in advance,
Asmo
