full_frame v3_landed_scaled.stl
The 3d-printed spherical frame (truncated icosahedron) used to hold modules together for soldering. Please note scale might not be 100% accurate based on your printer settings, module tolerance, etc. You might need to print few iterations and modify as needed.
Standard Tesselated Geometry -
278.99 kB -
10/20/2018 at 23:50
