HP 1660A series logic analyzer PC GUI
This project is intended to produce a modern graphical user interface for an old HP logic analyzer series to allow new use cases
HP 1660A series logic analyzers are an advanced type of o instruments with huge functionality and quite complicated user interface. They also lack ability to decode modern serial interfaces, but what they have is an outstanding hardware front ends and specifications (and dimensions) that surpass pretty much anything on the same modern price range.
HP 1660A AS Programmmers Guide.pdf
Adobe Portable Document Format - 4.50 MB - 05/06/2018 at 17:17
Preview
HP 1660A_users_ref.pdf
Adobe Portable Document Format - 2.68 MB - 05/06/2018 at 17:16
Preview
zakqwy wrote 05/05/2018 at 14:45 point
what Interface will you use to pull data out of the analyzer? HPIB?
jurkstas wrote 05/06/2018 at 09:46 point
Hi, thanks for asking. Both HPIB and RS232 are viable, RS232 being simpler to use. It does not need any special drivers if VISA is not used thus would require a shorter tool chain.
But now I am looking into the https://sigrok.org/ project. It would make a lot more sense to just write drivers for the instrument and use existing tool instead of trying to roll out something custom.
