All the components have arrived and today i started soldering the pcb!
I’m quite happy with the result 🙂 The only issue i have found till know is with the USB socket. For some strange reason the slots for its alignment pins were not generated in the NC drill files. So i had to chop off these pins from the socket and soldered them with the pad.
![](https://cdn.hackaday.io/images/449711532037183694.jpeg)
![](https://cdn.hackaday.io/images/2822931532037183790.jpeg)
![](https://cdn.hackaday.io/images/9585301532037238081.jpeg)
Wow, that is a pretty good job for manual soldering!
Thanks man 🙂
