All the components have arrived and today i started soldering the pcb!
I’m quite happy with the result 🙂 The only issue i have found till know is with the USB socket. For some strange reason the slots for its alignment pins were not generated in the NC drill files. So i had to chop off these pins from the socket and soldered them with the pad.
Carl Bugeja
Wow, that is a pretty good job for manual soldering!
Thanks man 🙂
