DFPlayer - A Mini MP3 Player For Arduino
<https://www.dfrobot.com/index.php?route=product/product&search=mp3&description=true&product_id=1121>
This example shows the basic function of library for DFPlayer.
Created 2014-8-28
By [Angelo qiao](Angelo.qiao@dfrobot.com)
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1.Connection and Diagram can be found here
2.This code is tested on Arduino Uno, Leonardo, Mega boards.
// rx 3
SoftwareSerial softSerial(RX, TX); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
void setup()
softSerial.begin(9600);
if (!myDFPlayer.begin(softSerial)) { //Use softwareSerial to communicate with mp3.
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
myDFPlayer.enableDAC();
delay(200);
myDFPlayer.volume(30); //Set volume value. From 0 to 30
myDFPlayer.play(1); //Play the first mp3
void loop()
if (myDFPlayer.available()) {
uint8_t type = myDFPlayer.readType();
if (type == DFPlayerPlayFinished)
// sleep();
// myDFPlayer.play(1);
myDFPlayer.disableDAC();
myDFPlayer.sleep();
mcu_sleep();
void mcu_sleep()
byte mcucr1, mcucr2;
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
MCUCR &= ~(_BV(ISC01) | _BV(ISC00)); //INT0 on low level
ADCSRA &= ~_BV(ADEN); //disable ADC
cli(); //stop interrupts to ensure the BOD timed sequence executes as required
mcucr1 = MCUCR | _BV(BODS) | _BV(BODSE); //turn off the brown-out detector
mcucr2 = mcucr1 & ~_BV(BODSE); //if the MCU does not have BOD disable capability,
MCUCR = mcucr1; // this code has no effect
MCUCR = mcucr2;
sleep_cpu();
